I need urgent help on w211 - Printable Version
+---- Thread: I need urgent help on w211 (/Thread-I-need-urgent-help-on-w211)
I need urgent help on w211 - shkumbim.bekteshi - 12-01-2016
MB W211 I need help about air bag flashing light in ICM, this problem has been showed after I changed the EZS, EZL and CDI control unit, I coded by DAS but the airbag light is flashing anyway, can you help me with coding to turn the lights, the DAS in airbag is not showing fault but the light is still flashing thankyou.
I need urgent help on w211 - Russ - 12-01-2016
Do an initial start up. The ecu is still unlocked that's why the light flashes.
Sent from my SM-T116 using Tapatalk
RE: I need urgent help on w211 - shkumbim.bekteshi - 12-01-2016
@Russ, I dont understand that well, can u tell me how to do an initial start up ?
RE: I need urgent help on w211 - janiszewskiadam - 12-01-2016
Das. Adaptation modules. Special functions. launch of a new module
RE: I need urgent help on w211 - dvdegrt - 12-01-2016
Yes me also had this trouble vhen used developer have to entrigeln vhen all coding complete need verigeln
Still have the problem, I clean the faults but when I startup the car the light is still flashing can you help me please?
RE: I need urgent help on w211 - alexjx - 12-01-2016
(12-01-2016, 04:49 AM)shkumbim.bekteshi Wrote: Still have the problem, I clean the faults but when I startup the car the light is still flashing can you help me please?
Did u do initial startup, and code it appropriately???
Uncoded srs control unit will cause the flashing srs.
RE: I need urgent help on w211 - bawarek - 12-01-2016
This is ARMADA SRS module and cannot be unlocked when the SSID(VIN) doesnt match the EIS. At least i was not able to do it in the car yet.
RE: I need urgent help on w211 - shkumbim.bekteshi - 12-02-2016
(12-01-2016, 10:00 PM)bawarek Wrote: This is ARMADA SRS module and cannot be unlocked when the SSID(VIN) doesnt match the EIS. At least i was not able to do it in the car yet.
okay I still have this problem, thank you very much guys.
