SBC_fault C24DB - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: SBC_fault C24DB (/Thread-SBC-fault-C24DB) |
SBC_fault C24DB - turja - 12-03-2016 Hallo, I was replaced SBC. New SBC is 005 431 96 12. And now I have this fault (C24DB). ESP number is 035 545 60 32. RE: SBC_fault C24DB - Mario3 - 12-03-2016 Did you check if this SBC number is compatible to your ESP unit ? If you cannot find the same SBC number you have to check in Epc which module numbers are compatible as replacement otherwise a new one wont work.. And reset the eeprom to RE: SBC_fault C24DB - turja - 12-03-2016 Ok, thanks for Your reply. How to reset the EEPROM? RE: SBC_fault C24DB - tachonow - 12-04-2016 DAS Developer... RE: SBC_fault C24DB - Mario3 - 12-05-2016 or avdi/fvdi can do it in seconds |
