722.9 vgs problem - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: 722.9 vgs problem (/Thread-722-9-vgs-problem) |
722.9 vgs problem - thushi91 - 12-05-2016 hello friends got a problem on a 722.9 w211 e320 cdi 642 engine changed electric plate and did scn but failed to transfer adaptation because part unavailability at time. No matter what seems to be jerking the torque converter. adaptation does not seem to solve problem. is there any method to transfer adaptation after scn is performed , since i received old part now?? please help! cheers! RE: 722.9 vgs problem - danrad - 12-05-2016 Hi SCN coding at moment not available until tomorrow. Check again when they server back to work. RE: 722.9 vgs problem - bawarek - 12-05-2016 I know that Autologic can transfer that data after the initial startup has been finished. I once had that problem with a 2006 C230. Initial start-up was done by the book, but the TQ was jerking no matter what I did. Valve body was old part number, which is supposed to be replaced complete with the VGS. After I replaced valve body+VGS all was good. RE: 722.9 vgs problem - janiszewskiadam - 12-05-2016 Check the number of EHS in the middle of the box and then type the correct coding offline or online. Good luck RE: 722.9 vgs problem - thushi91 - 12-06-2016 yes the EHS part number gets replaced to new part number automatically when entering in DAS. i guess that is the problem then, will try your advice bawarek thank you! RE: 722.9 vgs problem - luc.b - 12-06-2016 Could it be that you are using a VGS2 or a VGS3 Conductor plate, and the old one is a VGS1 Those valvebodys are different and you cant transfer the adaption data from the VGS1. I know we did this in the past, and we used Bluelink diagnostics services for SCN coding, and their adaption solution. This meant we had to drive the car for about 100km to complete the fine adaptions, but after that, it was working great. |
