MB system scaling on High DPI display - Printable Version
+---- Thread: MB system scaling on High DPI display (/Thread-MB-system-scaling-on-High-DPI-display)
MB system scaling on High DPI display - webmaster - 12-07-2016
Hi folks,
Does anyone managed to run Ewanet, DAS and Xentry on High DPI display without setting resolution to 1600 by 900 ( 14" display ) as it looks blurry and fuzzy!
I spent many days to find good solution but non of them worked...
Its really pain to let you know that buying a laptop with 4K or very high resolution right now is a waste of money No
Better you stuck on Dell E6410... Recommended Tup
I got new X1 one carbon and maybe very soon I will throw it in garbage!
Best regards.
RE: MB system scaling on High DPI display - Rocinante - 12-07-2016
I run 1920 x 1080 on my Dell E6510 but as I get older, its getting harder to read without glasses Sad
I find the native E6510 1600x900 screen much easier to read..
I keep a set of reading glasses next to my laptop now..
RE: MB system scaling on High DPI display - qwertyl4b - 12-07-2016
Windows 10 have Display Scaling for 4k.
I don't know What OS You use.
RE: MB system scaling on High DPI display - webmaster - 12-07-2016
(12-07-2016, 04:35 AM)deviance Wrote: Windows 10 have Display Scaling for 4k.
I'm using windows 10
Windows 10 Java font size are too small on hidpi
Disable High DPI from compatibility didn't help...
I think its java issue. It's not able to scale correctly! I changed some parameters in java.exe and javaw.exe but nothing changed...
I changed fonts in wisconfig for example to see if this will work, the txts come one above the other! Fing20
Best regards.
RE: MB system scaling on High DPI display - qwertyl4b - 12-08-2016
You can use -Dsun.java2d.dpiaware=false if you using Java 6 or 7.
Why not working under 8-9? Bug:
Code:
https://bugs.openjdk.java.net/browse/JDK-8080153
Maybe:
Code:
http://stackoverflow.com/questions/30555401/java-disable-dpi-aware-not-working
RE: MB system scaling on High DPI display - webmaster - 12-09-2016
Thanks for info,
I already applied these steps but didnt work with me...
Maybe I missed a step.
Ill give it another try and see Smile
Thank you
RE: MB system scaling on High DPI display - qwertyl4b - 12-10-2016
If not working just chill... This is java!
Do you know where live the world's slowest animal? On the Java Island. haha
RE: MB system scaling on High DPI display - webmaster - 12-12-2016
(12-10-2016, 06:06 PM)deviance Wrote: If not working just chill... This is java!
Yes not worked....
The entire laptop has conflict in scaling and resolution.. If you watch the Device Manager page, u will see blurry and fuzzy txt, if you change to 1600X900 its will look better but still not fine for me... Its very fast, very nice, very expensive and USELESS....
Best regards.
RE: MB system scaling on High DPI display - qwertyl4b - 12-13-2016
You should try this Big Grin
Code:
https://support.microsoft.com/en-us/help/11542/windows-use-magnifier
