SOLVED - Flash Door Control Module - non-working window - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: SOLVED - Flash Door Control Module - non-working window (/Thread-SOLVED-Flash-Door-Control-Module-non-working-window) |
SOLVED - Flash Door Control Module - non-working window - edwin.dario - 12-08-2016 Hi all, I finally have my C3 MUX working using an installation guide for Xentry 9/2014+SDMedia. I did the installation as per the guide and did nothing else. The C3 MUX is working and reading fine. On the weekend, my driver's power window on my 2007, S550 (W221) stopped working. The "Actual Values" of the module shows that the switch is working properly. I did a search and it appears that many people are able to solve their issue by flashing the door module: Code: http://mbworld.org/forums/s-class-w221/377008-driver-window.htmlThe above thread references the following bulletin: Code: http://workshop-manuals.com/mercedesbenz/cl_63_amg_%28216.377%29/v8-6.3l_%28156.984%29/windows_and_glass/windows/power_window_control_module/component_information/technical_service_bulletins/customer_interest_for_power_window_control_module/p-67_39-22b/sep/08/body_power_window%28s%29_are_inoperative/My question is the following: Can anybody direct me to a link which will allow me to complete the following operation using my existing hardware / software: To resolve, flash the applicable door control module using SDS version 08/08 or later, via SDS menu path: Control units --> Seats and doors --> DCM-XX - Door control module (Choose DCM with the issue) --> Control unit adaptations --> Control module programming. Do not replace any parts. Many thanks in advance! RE: Mercedes - Flash Door Control Module - alexjx - 12-08-2016 if your mux is working, just perform a programming on that module and should be fine. "DCM-XX - Door control module (Choose DCM with the issue) --> Control unit adaptations --> Control module programming. " RE: Mercedes - Flash Door Control Module - edwin.dario - 12-08-2016 (12-08-2016, 07:28 AM)alexjx Wrote: if your mux is working, just perform a programming on that module and should be fine. Don't I need access to any programming? The computer is not currently plugged to the internet. RE: Mercedes - Flash Door Control Module - alexjx - 12-08-2016 (12-08-2016, 07:33 AM)edwin.dario Wrote:(12-08-2016, 07:28 AM)alexjx Wrote: if your mux is working, just perform a programming on that module and should be fine. no need for it. but is ur das "offline programming" enabled? if no, head over to pesona's thread. RE: Mercedes - Flash Door Control Module - edwin.dario - 12-11-2016 I downloaded Pesona's "XDOS 12-2015 32BIT SDCONNECT ACRONIS IMAGE AHCI" and restored the backup to my HP 6930P Elitebook and its dock (for serial port). The image works fine with my C3 MUX. I presume that it has "offline programing" enabled. Notwithstanding, I get the following error: image hosting adultIs anyone familiar with that error? Many thanks, RE: Mercedes - Flash Door Control Module - edwin.dario - 12-15-2016 Hi all, What a relief, I no longer need to open my car door at a drive through!!! Flashing the software worked. I headed to Pesona's thread and did as instructed, namely: Hi, here is offline programming for vehicles: PKW + SMART Software: Xentry XP, XDOS(32/64) Release: 2015 until 09-2016. Full flashen folder + how to How to: (1.01) 1. Rename original flashen folder in: das\trees\pkw to e.g: flashenORI 2. Extract and copy the offline flashen So in the das\trees\pkw you have two folders: Flashen ; for offline programming FlashenORI ; original folder. Maybe you want to use for online programming All of the credit goes to Pesona! |
