Error 1.501.9877 das 09/2016 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Error 1.501.9877 das 09/2016 (/Thread-Error-1-501-9877-das-09-2016) Pages:
Error 1.501.9877 das 09/2016 - M3L3R - 12-18-2016 Hi! I cant connect with w221 and w169. I connected with w163, r170, w203, w204(xentry) all of them are ok. I have that clone unit for 2weeks, I bought it with hdd(win7) for dell d630. Version of mux: OS: 2.3.20130523 CSD: 2.11.20150601 I renamed upade folders, but nothing changed. Any solution to fix that error 1.501.9877? ![]() At this moment I have w169 for test. RE: Error 1.501.9877 das 09/2016 - M3L3R - 12-19-2016 I connected also with w211 2005. RE: Error 1.501.9877 das 09/2016 - carlo - 12-19-2016 what else you have installed with this version? dts? vediamo? RE: Error 1.501.9877 das 09/2016 - M3L3R - 12-19-2016 Vediamo RE: Error 1.501.9877 das 09/2016 - M3L3R - 12-31-2016 X164 doesnt work also :/ Does someone have any solution on that or suggestion? RE: Error 1.501.9877 das 09/2016 - Rocinante - 12-31-2016 That's a hardware communication problem.. might be a bad MUX.. can you try another one? RE: Error 1.501.9877 das 09/2016 - M3L3R - 12-31-2016 I dont have another unit, but Ill install version 2015.09 and check results. RE: Error 1.501.9877 das 09/2016 - M3L3R - 01-18-2017 Another version 2015.12 working with all cars! Now I need offline programming? Does someone have actronic image for dell d630 with enable offline programming? Is it possible to turn on that function on my version 2015.12? Thanks!
RE: Error 1.501.9877 das 09/2016 - sigaik - 01-18-2017 Pesona is the correct man to ask. ![]() http://mhhauto.com/Thread-DAS-PKW-SMART-Transporter-Offline-Programming-2014-2015-2016-Tested-and-updated?pid=745739#pid745739 |
