Eis w208 clk - Printable Version
+---- Thread: Eis w208 clk (/Thread-Eis-w208-clk)
Eis w208 clk - antoniourbauto - 12-18-2016
Hello. I have a mercedes clk w208 with ezs 210w, I cloned an eis, I soldered two mcu 1d69j in another eis and it does not work, it recognizes the keys, when I use the other eis it communicates diagnosis.pero still does not work. Somebody knows how can Do or how to get pasword to change this?Sweating
(12-18-2016, 07:55 PM)antoniourbauto Wrote: Hello. I have a mercedes clk w208 with ezs 210w, I cloned an eis, I soldered two mcu 1d69j in another eis and it does not work, it recognizes the keys, when I use the other eis it communicates diagnosis.pero still does not work. Somebody knows how can Do or how to get pasword to change this?Sweating
RE: Eis w208 clk - mb_port - 12-18-2016
old big key?often lost data,generiere new dump and use nec key
RE: Eis w208 clk - antoniourbauto - 12-18-2016
Thank you very much. But I do not understand you well.
The key is version 35 nec and this is the w210 version.I have read the two dump of the mcu.but I do not know what to do
RE: Eis w208 clk - antoniourbauto - 12-20-2016
Up
RE: Eis w208 clk - PedroX5 - 12-21-2016
Hi if i understad it right, you put both MCUs in to the other used EIS?
You have only to swap contens of mcu eeproms only. Probably one of youre MCU is damaged.
RE: Eis w208 clk - antoniourbauto - 12-21-2016
Thank you very much.I have put mcu in another eis.he recorded dumps in mcu of another eis and it does not work.he sent a car to mercedes.
I thought the same as you told me
Thank you very much pedro
bad is that find new unprogrammed x68hc05x32 for sale is dificult.
RE: Eis w208 clk - antoniourbauto - 12-22-2016
(12-21-2016, 04:00 AM)PedroX5 Wrote: bad is that find new unprogrammed x68hc05x32 for sale is dificult.
Yes is dificultFing32
