cl 500 w215 acceleration pedal not work after flat battery - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: cl 500 w215 acceleration pedal not work after flat battery (/Thread-cl-500-w215-acceleration-pedal-not-work-after-flat-battery) |
cl 500 w215 acceleration pedal not work after flat battery - yanko - 12-27-2016 Yestarday my mercedes cl500 was stay with flat battery and then when crank gas pedal not working ... What i need to do RE: cl 500 w215 acceleration pedal not work acter flat battery - BenzBhoy - 12-27-2016 (12-27-2016, 01:44 PM)yanko Wrote: Yestarday my mercedes cl500 was stay with flat battery and then when crank gas pedal not working ... What i need to doHi Replace your airmass meter! Regards RE: cl 500 w215 acceleration pedal not work acter flat battery - @batterypack@ - 12-27-2016 is the other battery ok ? RE: cl 500 w215 acceleration pedal not work acter flat battery - Rocinante - 12-27-2016 Leave the key on and engine off for a couple of minutes to relearn the throttle stop in the engine control unit.. if you listen to the throttle actuator, you can hear the tone change when its learning.. After its done learning, turn the key back off for 10 seconds, then start your car
RE: cl 500 w215 acceleration pedal not work acter flat battery - kin1830 - 12-28-2016 acceleration pedal RE: cl 500 w215 acceleration pedal not work after flat battery - yanko - 12-28-2016 Rocinate thanks !!! RE: cl 500 w215 acceleration pedal not work after flat battery - Rocinante - 12-28-2016 So that worked for you?
RE: cl 500 w215 acceleration pedal not work after flat battery - antoniourbauto - 12-30-2016 Warning with change the battery all mercedes.modul sam brokens. |
