w221 cannot teach-in ISM - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: w221 cannot teach-in ISM (/Thread-w221-cannot-teach-in-ISM) |
w221 cannot teach-in ISM - EASatlanta - 12-28-2016 Hello guys, Have w221 here, using 09/2016 that Yudi has checked over and I have successfully done SCN. w221 came to me with no transmission in the car. We put used transmission with valve body. Performed SCN, success. Trying to teach in ISM, ism fails. The first time I tried, it saw P for park, then would not let me move it to R or D. Now when I try teach-in I get this error: No communication 8.600.0 Any ideas? ![]()
RE: w221 cannot teach-in ISM - viktor - 12-28-2016 Hello. Change ISM on new or used (need renew) then teach. In my case with ISM w221 same error. It have physical damage. Best regards RE: w221 cannot teach-in ISM - KG7222 - 12-29-2016 First you must to renew the ISM, then calibrate and coding offline with battery charger. Regards! RE: w221 cannot teach-in ISM - yriy - 12-29-2016 I had the same problem. I decided with the old version das. RE: w221 cannot teach-in ISM - asimor - 01-04-2017 I have same problem!
RE: w221 cannot teach-in ISM - KG7222 - 01-04-2017 1) if you want to install second hand ISM you must to buy from the same car. If you have w164 you must to buy from w164... 2) must to virginize the module 3) do initializate and calibrate the gears 4) star the car and have fun RE: w221 cannot teach-in ISM - KriyenKPp - 01-05-2017 (01-04-2017, 11:01 PM)mbsupport Wrote: 1) if you want to install second hand ISM you must to buy from the same car. If you have w164 you must to buy from w164... what tools can be used to virginise this module
RE: w221 cannot teach-in ISM - viktor - 01-05-2017 (01-05-2017, 12:43 AM)KriyenKPp Wrote:(01-04-2017, 11:01 PM)mbsupport Wrote: 1) if you want to install second hand ISM you must to buy from the same car. If you have w164 you must to buy from w164... VVDI MB TOOL, FVDI, DIAGSPEED ETC. RE: w221 cannot teach-in ISM - KriyenKPp - 01-05-2017 can avdi do this as well--virginise ?
