DAS Crashes when viewing actual data - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: DAS Crashes when viewing actual data (/Thread-DAS-Crashes-when-viewing-actual-data) |
DAS Crashes when viewing actual data - spastik monkey - 12-30-2016 I received my C4 today. I'm working with a cluster swap, and when I try to view the actual data, the DAS app crashed and prompts me to send windows error data. Is there a fix? its a 2015 version of the software RE: DAS Crashes when viewing actual data - Yoshimitsu - 12-30-2016 I had similiar with that. It happens to me when i worked with DAS via WiFi. With LAN Cable it worked as it should. Xentry worked with and without cable without errors. Did you have same situation? RE: DAS Crashes when viewing actual data - spastik monkey - 12-30-2016 (12-30-2016, 04:51 AM)Ilja Wrote: I had similiar with that. It happens to me when i worked with DAS via WiFi. I'm getting it with the cable, I don't have wifi RE: DAS Crashes when viewing actual data - Rocinante - 12-30-2016 Are all the updates installed? RE: DAS Crashes when viewing actual data - spastik monkey - 12-31-2016 (12-30-2016, 06:33 PM)Rocinante Wrote: Are all the updates installed? windows updates, or updates to the xentry suite? RE: DAS Crashes when viewing actual data - camaro - 12-31-2016 (12-31-2016, 02:38 AM)spastik monkey Wrote:(12-30-2016, 06:33 PM)Rocinante Wrote: Are all the updates installed? @Rocinante, mean enough Xentry RE: DAS Crashes when viewing actual data - Rocinante - 12-31-2016 Xentry/DAS updates.. RE: DAS Crashes when viewing actual data - spastik monkey - 01-01-2017 (12-31-2016, 10:21 PM)Rocinante Wrote: Xentry/DAS updates.. I think it's been trying to update for 2 days now. The little blue arrow in the task bar has been running. RE: DAS Crashes when viewing actual data - Rocinante - 01-01-2017 You have to install the updates manually if the software is more than 3 releases old.. Look in the software section for the downloads for the updates |
