w220 will not power c4 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: w220 will not power c4 (/Thread-w220-will-not-power-c4) |
w220 will not power c4 - tritron - 01-02-2017 I have 2000 S430 I was trying to run diagnostics but w220 will not power C4. I put batteries in and it will but but I cant run any diagnostics I get check pins error message. My c4 works fine with my ML350 no issues. I had no isuue code module in it. Do I have wiring issue on the plug, I checked fuses and they are ok. ODB reader works fine. C3 had green light but I think it is defective could not run diagnostics wih it. RE: w220 will not power c4 - HestonDiag - 01-02-2017 Get multimeter to test car OBD port. Pins 4+5 should be earth, pin 8 is switched 12v, pin 16 is permanent 12v. If tool is not powering up, will be problem with pin 4,5 or 16 on car. |
