Need WIS document GI27.00-P-002614 - Printable Version
+---- Thread: Need WIS document GI27.00-P-002614 (/Thread-Need-WIS-document-GI27-00-P-002614)
Need WIS document GI27.00-P-002614 - KG7222 - 01-05-2017
Hello friends,
I need WIS document GI27.00-P-002614 on english. I found only on russian language, but I can't understand nothing for my problem with W168 and 722.7 transmission
Thanks.
RE: Need WIS document GI27.00-P-002614 - Kaluluka - 01-05-2017
That document is from XENTRY TIPS, not from WIS.....
RE: Need WIS document GI27.00-P-002614 - Rocinante - 01-05-2017
I've never heard of a GI document.. LI is in Tips..
The WIS document in your GI document is AR27.50-P-0570GC for Disassemble and Assemble Countershaft..
RE: Need WIS document GI27.00-P-002614 - KG7222 - 01-05-2017
WIS...TIS..XENTRY...nevermind Smile Have someone this document?
I have this fault code on W168 with 722.7
Code:
P2530 - the hydraulic pressure in component Y3/7y1
(pulse width modulated solenoid valve 1/4 shift) and (or) at regulating valve 2/5/R is too high or at regulating valve 2/5/R too low.(Warning: please refer to the STIP documents GI27.00-P-002614. )
RE: Need WIS document GI27.00-P-002614 - DBmhh - 01-05-2017
(01-05-2017, 08:54 PM)mbsupport Wrote: WIS...TIS..XENTRY...nevermind Smile Have someone this document?
PM me if you still need the document. Don't want to post it here with my credentials (and I'm too lazy to edit it out).
RE: Need WIS document GI27.00-P-002614 - roger1969 - 01-07-2017
[attachment=162691]
Code:
Try this one. Hope it helps..
Regards.
RE: Need WIS document GI27.00-P-002614 - DBmhh - 01-07-2017
There was a reference to a pdf document. I seem to have printed the one in German language, perhaps there would have been one in English too.
RE: Need WIS document GI27.00-P-002614 - babijoe - 01-10-2017
(01-07-2017, 08:41 PM)DBmhh Wrote: There was a reference to a pdf document. I seem to have printed the one in German language, perhaps there would have been one in English too.
Hi, find attached.
RE: Need WIS document GI27.00-P-002614 - DBmhh - 01-11-2017
(01-10-2017, 01:32 PM)babijoe Wrote: Hi, find attached.
I don't need the document and in addition your document is no different from the one that was already shared (except that you did not remove your user name).
I was after the pdf that GI27.00-P-002614_Ver_7.pdf refers to. It is the attachment GI27.00-P-002614_1.pdf with the title "Diagnosehilfe bei F im Display.pdf".
Nothing important though, just wanted to clarify what I was after.
