W219 with M272 fuel found in exaust - Printable Version
+---- Thread: W219 with M272 fuel found in exaust (/Thread-W219-with-M272-fuel-found-in-exaust)
W219 with M272 fuel found in exaust - ivannzowa - 01-06-2017
Hello,i have problem with w219 cls with 272 engine.the old ecu was dead,then i found another working ecu,renewed it and programmed it,car started fine but the fuel consumption is too big,and i found a lot of fuel in exhaust.can it be control or there is something am supposed to do
Sent from my iPhone using Tapatalk
RE: W219 with M272 fuel found in exaust - strikeforce - 01-06-2017
(01-06-2017, 12:36 AM)ivannzowa Wrote: Hello,i have problem with w219 cls with 272 engine.the old ecu was dead,then i found another working ecu,renewed it and programmed it,car started fine but the fuel consumption is too big,and i found a lot of fuel in exhaust.can it be control or there is something am supposed to do
Either you have a shorted injector that is continuosly on or the injector driver in the ecu is shorted and always on. Your catalytic converter may also likely be melted.
RE: W219 with M272 fuel found in exaust - ivannzowa - 01-06-2017
Ok,i get you...can this happen even if the car has no misfire?
(01-06-2017, 03:34 PM)ivannzowa Wrote: Ok,i get you...can this happen even if the car has no misfire?
Normally cel/mil should flag a misfire code but in some instances no misfire dtc is flagged off. Scanner Danner on YouTube has case study videos on this issue. Search for his videos and you may find his e-book very interesting.he is a very experienced auto diagnostic mechanic with over 20 yrs experience in the field.
In the situation where no misfire dtc is stored, you can use a test light to test for short in the injector harrness or scope the injector to analyse the voltage and current.
