2003 R230 SL500 instrument cluster communication error - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: 2003 R230 SL500 instrument cluster communication error (/Thread-2003-R230-SL500-instrument-cluster-communication-error) |
2003 R230 SL500 instrument cluster communication error - mertd93 - 01-06-2017 Hello gents, As the title says I have a 2003 R230 SL500 which has an instrument cluster communication error, it's the only module that I can't connect with sds machine. Cluster works fine I put it in a friends car and can connect to it just fine, only in my car it won't connect, seems I have some CAN issue and cluster is not seen on the network, has anyone ever experienced anything similar? Mike RE: 2003 R230 SL500 instrument cluster communication error - Mackhack - 01-06-2017 Show the error message in your fault memory as well as the DAS error you're getting when you try to connect. RE: 2003 R230 SL500 instrument cluster communication error - mertd93 - 01-06-2017 It's the same error as if you have a module unplugged, I will post a picture tomorrow. RE: 2003 R230 SL500 instrument cluster communication error - Rocinante - 01-06-2017 First make sure you have all your powers and grounds.. Next see if you have CAN voltage at the cluster connector, if it has a K-line to the X11/4 make sure that wire isn't shorted or open... |
