actros immo off - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: actros immo off (/Thread-actros-immo-off) |
actros immo off - waliddahan - 12-08-2012 heloo all members please need help to do this car off becuse its dont accpt key ther is code in dash poard dump in attach regards RE: actros immo off - megapali - 12-09-2012 Have you checked the wiring MR (PLD) via RF (MRF) via A42 (KEY RING)? RE: actros immo off - waliddahan - 12-09-2012 (12-09-2012, 12:50 AM)megapali Wrote: Have you checked the wiring MR (PLD) via RF (MRF) via A42 (KEY RING)? thanks for u.r replay put chore car digramm 100% ok only losed key but i thenk he try crank meany time befor is this losed adption or do ecu locked and how can fix its regards RE: actros immo off - johary - 02-13-2013 HELLO Waliddahan!! to fix it, you need to find a MB VARIO or a 814D TRUCK or BUSES, you have just to copy its EEPROM(93CXX) to the ACTROS because in these type of truck, no immo mounted with MR/PLD and FR. When u finish to copy the data, try to start it without FMR ECU(just disconnect the 4th connector) good luck!! RE: actros immo off - hugos31 - 03-30-2016 please , help me . I nee immo off
RE: actros immo off - Advanced trucks - 11-26-2016 i can help you with immo off eeprom+flash but for pld only not fr if ok contact me dont blame me for late reply i was away with some issues |
