W221 facelift battery drain - Printable Version
+---- Thread: W221 facelift battery drain (/Thread-W221-facelift-battery-drain)
W221 facelift battery drain - phydor - 01-12-2017
Hi there guys,I have a problem with a W221 2010 facelift model.It drains the battery in about two hours so i am not able to start the engine.I ve bought it on friday so I don t have very much info.I ve seen the owner changed the battery a month ago.
I noticed a strange noise after stopping and locking the car that i think originates from the airmatic pump.
I get no errors in DAS besides
"9001 N93 CGW unit defective" and
"The coding for component Y42/12 DRiver Neck Pro Solenoid head restraint is invalid.
I suppose he changed the mileage at some random garage that s why I get that CGW error.
Yesterday i measured the quiescent current with DAS and was measuring 0.0 V after actuating the F32K2 shutoff relay.But even without that noise stopped after using shutoff relay,the car didn t start in the morning.Not enough energy to crank.If i remove one of the poles it would start no matter the time between the starts.
Any ideas?I m guessing Front SAM may be causing this but i don t have another one to test my theory..Fing20
RE: W221 facelift battery drain - Rabih AMG - 01-12-2017
Sit in the car and lock it for about 5 mins and see if you can hear some noises inside the car.
RE: W221 facelift battery drain - darmoyan917 - 01-12-2017
If the CGW (Central Gateway) is defective, the entire audio/navigation/radio system is not going to sleep. Just disconnect the central gateway and test again. Then replace it. Or if you have wiring diagrams you can just remove the fuse.
EDIT
Nevermind, mixed it up with audio gateway. You might have to just do the old fashioned current test with multimeter and start pulling fuses. I know on the older ones had bad driver seat modules that would cause batter drain. Audio gateway doesn't have any codes? MOST ring open or incorrect?
RE: W221 facelift battery drain - Raints - 01-13-2017
Use this http://mhhauto.com/Thread-W211-E220-need-battery-drain-fix?pid=803508#pid803508 information to check voltage drop.
Dont pull fuses out, use good multimeter switch it on mV and DC range.
And you can find where is problem.
All readings should be zero.
It is very easy.
RE: W221 facelift battery drain - phydor - 01-13-2017
I will check them at my garage on saturday but what made me curious was that the electrohydraulic pump doesn t go to sleep.In the first post i ve said Airmatic compressor but it s the power steering pump actually.Even after 20 minutes it s still making a buzzing sound that s not continuos.So,yesterday i ve used that shutoff relay,the noise stopped but i still had a drained battery in the morning.
My question is if is there any chance that CAN blocker installed in the dash could make some kind of CAN issue?I suppose there is one after the different readings of mileage between IC ans EIS and the N93 unit defective message i get.
If i try offline programming would make things better?I suppose the mileage would revert to correct value.But i don t know what will happen if i try offline programming with that thing installed.
In any case,i will do the measurements you suggested.
P.S.I can hear though a clicking sound every now and then in the dash after i use shutoff relay F32K2..
RE: W221 facelift battery drain - Rocinante - 01-13-2017
The electric P/S pumps are very problematic... Disconnect the connector from it, it will keep the CAN awake if the P/S fluid leaked into the bottom where the electronics are..
