Das fail to communicate with car - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Das fail to communicate with car (/Thread-Das-fail-to-communicate-with-car) |
Das fail to communicate with car - ivannzowa - 01-12-2017 https://vimeo.com/199153822 hello as shown on video,i have problem with se connect which cannot communicate with car,i tried to update manual firmware but still no lucky,help me please,may be the problem is software not mux Sent from my iPhone using Tapatalk RE: Das fail to communicate with car - EASatlanta - 01-12-2017 firmware problem... you may have bricked your mux.' Search for webmasters guide on updating mux firmware, good luck. PM if you need help. RE: Das fail to communicate with car - ivannzowa - 01-12-2017 (01-12-2017, 06:47 PM)EASatlanta Wrote: firmware problem... you may have bricked your mux.' I tried it with no luck RE: Das fail to communicate with car - EASatlanta - 01-12-2017 (01-12-2017, 06:50 PM)ivannzowa Wrote:(01-12-2017, 06:47 PM)EASatlanta Wrote: firmware problem... you may have bricked your mux.' yeah sounds like hardware problem bud... too bad. not a hard fix though. RE: Das fail to communicate with car - ivannzowa - 01-12-2017 I updated manual mux sucessfull but still not work RE: Das fail to communicate with car - EASatlanta - 01-12-2017 (01-12-2017, 06:58 PM)ivannzowa Wrote: I updated manual mux sucessfull but still not work Yes, I know I was in the same situation at one point. What steps did iyou follow? Can you post the thread? RE: Das fail to communicate with car - Tackey - 01-12-2017 Hi, I had same kind of problem. It happenes only DAS cars. What I did was.. Just run Mux self test. sometimes, self test failes. But if you try several times, finally it must go success. After Self test runs good, Mux can connect cars. It happened on my mux bought from OBD2tuning. Please try it ,even if it sounds stupid. RE: Das fail to communicate with car - EASatlanta - 01-12-2017 http://mhhauto.com/Thread-Sdconnect-Update-Files-1st-web-release RE: Das fail to communicate with car - ivannzowa - 01-12-2017 Finaly solved,after firmware update,i forgot to change name for update folders,i changed names and also edit update time in bin folder to 0 ,now everything is working sucessful |
