Cloned STAR MAC & IP mismatch - Printable Version
+---- Thread: Cloned STAR MAC & IP mismatch (/Thread-Cloned-STAR-MAC-IP-mismatch)
Cloned STAR MAC & IP mismatch - crippo2 - 01-14-2017
Hi Need some information/help please
I recently bought what appears to be a copy of the Mercedes STAR/Xentry (STAR) product version 09/2014, running on a Dell Latitude D620 and connecting to the vehicle through the C3 wired module. As part of the purchase I also got what seem to be stand alone (single user) versions of EPC, WIS and Vediamo (sp?) V4
The XP pro Operating system & STAR software sits on an encrypted. 128GB Kingston SSD.
I have managed to clone the entire supplied SSD to give me a working system backup.
The STAR software has restricted functionality (eg no TIPS, no DataCard Access & limited printing), but other than that and an expiry date of end 2019, appears to work OK, albeit that EPC initiation can be a bit hit & miss.
My questions concern the several MAC addresses which the Dell PC appears to know. There is one for the Wired LAN, a second for the Wireless LAN and a third (virtual) Mac Address linked to the LAN connection of the PC on which the system cloning took place.
It is this 3rd (virtual) MAC address which is bound to the STAR Keys, as is the IP address of this virtual LAN card.
Attempting to access the internet from within the STAR encapsulation always fails, because it gets blocked by my IT system.
Using the Wired LAN connection (which gets its IP address through DHCP) allows connection to the internet, but only once STAR has been closed.
I want to get rid of the virtual MAC and IP addresses and change the MAC address to one in my Dell PC.
Which should I go for – Wired (which I prefer and would want use) or Wireless?
Assuming I go Wired (MAC is 00-18-8B-A4-3C-AD) will I need new keys for STAR and its components (including EPC and WIS)
All thoughts gratefully received - & thanks in advance
RE: Cloned STAR MAC & IP mismatch - Rocinante - 01-15-2017
Changing the MAC should only affect EPC and WIS (if not standalone).. You will only have to insert new keys. The keygens are available here for free or you can post in the appropriate thread and ask for new keys Wink
Cloned hard drives usually require a new Xentry key as well...
RE: Cloned STAR MAC & IP mismatch - crippo2 - 01-16-2017
(01-15-2017, 03:13 AM)Rocinante Wrote: Changing the MAC should only affect EPC and WIS (if not standalone).. You will only have to insert new keys. The keygens are available here for free or you can post in the appropriate thread and ask for new keys Wink
OK so as I understand what you are saying; if I change the MAC address to the wired LAN adapter I will need new Keys for both WIS and EPC AND (because my SSD is cloned) another Key for DAS/Xentry as well.
Sorry what do you mean by '(if not standalone)' Do you mean single user or as a completely separate entity and install from DAS/Xentry - please explain
Hopefully I can ask for the new keys on this forum, and hopefully these keys will both work and extend the date beyond end 2019
Have I this right? (I want to understand what I need to do before plunging in!)
RE: Cloned STAR MAC & IP mismatch - crazy40 - 01-16-2017
I had few CN and very hard it is to make it work. I cloned them but issue was unit is locked with license assign to a fake person. You are trying to beat the biggest cloned maker in the world. New keys for Xentry, DAS and WIS wont make it work. They are locked with license assign to a fake one. Their are plenty of guide how to circumvent the CN locked. You need to swap the bin file. Why bother?
Download one of the torrent and you are done. Then you can put any expiry you want with key-gen.
RE: Cloned STAR MAC & IP mismatch - DBmhh - 01-16-2017
(01-16-2017, 07:34 AM)crazy40 Wrote: I had few CN and very hard it is to make it work. I cloned them but issue was unit is locked with license assign to a fake person. You are trying to beat the biggest cloned maker in the world. New keys for Xentry, DAS and WIS wont make it work. They are locked with license assign to a fake one. Their are plenty of guide how to circumvent the CN locked. You need to swap the bin file. Why bother?
Downloading a HDD image from this forum is likely a better option than making a Chinese HDD work. However, their copy protection is most often pretty simple. Simple because you can find their different methods from this forum and instructions how to make the SW free.
Most often it is sufficient to change one file (mbtext.dll, das32r2.exe, xentry.exe etc.) from their modified (protected) version to the original one. Obviously original files are available from this forum.
The advantage of fixing the Chinese SW is that one can easily manage it with very low internet speeds (if that happens to be an issue).
Thank you
I will have a further look into this & hopefully get it sorted out!
however can you please explain "Most often it is sufficient to change one file (mbtext.dll, das32r2.exe, xentry.exe etc.)". you refer to changing one file, then mention 3 files by name and indicating there may be more. Is there somewhere I can find the full instructions to do this?
Thanks again
RE: Cloned STAR MAC & IP mismatch - Rocinante - 01-16-2017
It really depends on the if you have a Chinese software lock or not.. and which one they used..
As far as the WIS standalone means its not attached to EWA.net like EPC has to be, so the key is in a different place and isn't affected by MAC address changes..
(01-16-2017, 07:20 PM)Rocinante Wrote: It really depends on the if you have a Chinese software lock or not.. and which one they used..
Thank you - I begin to understand all this - I think
It all seems hugely complicated & I am now thinking it makes more sense for me to start again with am image of the entire system either from here or bought online - I have very slow internet access at present, so probably the latter.
I am away for a week or so & will try again early Feb
In the meantime many thanks to all who have responded to my question - I obviously still have a lot to learn!
