How to connect SAM-F with Vediamo - Printable Version
+---- Thread: How to connect SAM-F with Vediamo (/Thread-How-to-connect-SAM-F-with-Vediamo)
How to connect SAM-F with Vediamo - spark - 01-16-2017
Hi Guys
I try to setup a comunication between Vediamo and a not installed SAM-F (taken from a SLK R171)
To realize this I use the wiring diagram from WIS. For Power (Sam and C4)I use a 12Volt power supply.
Right now I cant see the trees in the Forest. It is not posible to wake up the SAM and connect it with Vediamo
Can anybody help me out? I like to test and learn Vediamo by using the SAM outside the Car.
I use the following connections:
Connector Sam------Pin------OBD-Socket
2------------------12----------8
2-------------------5---------GND
1-----------------1,2,3--------16 (12v)
6------------------23----------3
20-----------------1-----------6
20-----------------2-----------14
or do I miss something
I appreciate any help
Spark
How to connect SAM-F with Vediamo - rabaukee - 01-22-2017
Did you set baudrate to 500000 in Vediamo (in cff connection settings)?
RE: How to connect SAM-F with Vediamo - freakit - 01-22-2017
is it working now?
RE: How to connect SAM-F with Vediamo - spark - 01-22-2017
Hi
I set Baudrate to 500000--> No success
No! It works not.
I get always the error " Reizung fehlgeschlagen"
It seems the SAM_F from R171 needs a ZGW for communication
Right now I stuck...
Any Help please
check in vediamo help.have little info about working on ecu whitout a car . i also have no sucsses using vediamo on bench
can or k line? on r171 sam
RE: How to connect SAM-F with Vediamo - xzt - 01-22-2017
Hy mate you need a can rezistor to conect the sam and mux!
doesn`t it have in the sam?!
(01-22-2017, 07:58 PM)freakit Wrote: doesn`t it have in the sam?!
no..
but you mean 120ohm resistror between the can or this tiny white boxes for the can comunication?! sorry i`m in home cant see the mask of this component
