XENTRY INTERNAL ERROR: (3.824)-3.206 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: XENTRY INTERNAL ERROR: (3.824)-3.206 (/Thread-XENTRY-INTERNAL-ERROR-3-824-3-206) Pages:
XENTRY INTERNAL ERROR: (3.824)-3.206 - j4g3d - 01-17-2017 12.2016 W7 32bit Xentry worked fine then receive this error. Any solution?. I not install ANY addons, because when i do this many things stop working properly. RE: XENTRY INTERNAL ERROR: (3.824)-3.206 - crazy40 - 01-18-2017 It is Xentry blacklist internal error. There are plenty of solution in our forum. Delete all key from LicDir and redo them. Pay attention to SSL(RSA) that you used for diagservice jar file and avoid double CERT issue? RE: XENTRY INTERNAL ERROR: (3.824)-3.206 - Egyman - 01-18-2017 (01-17-2017, 07:34 PM)j4g3d Wrote: 12.2016 Send me TV i will fix your Problem RE: XENTRY INTERNAL ERROR: (3.824)-3.206 - j4g3d - 01-19-2017 ARGGHHHHH!! Now i get no error message and xentry just goes to open but then closes!. Also startkeycenter no longer works. I HAVE NOT TOUCHED ANYTHING, other than deleting lic_key_2x4711 because i entered a new key previously. Nothing else is touched. But things slowly keep stopping working??? XENTRY INTERNAL ERROR: (3.824)-3.206 - EASatlanta - 01-19-2017 You have to install addons... just apply blacklist fix after addons Sent from my iPhone using Tapatalk RE: XENTRY INTERNAL ERROR: (3.824)-3.206 - j4g3d - 01-19-2017 (01-19-2017, 06:28 AM)EASatlanta Wrote: You have to install addons... just apply blacklist fix after addons Not. Let me explain properly.. -12.2016 installed -Everything working absolutely perfect for 2 days -1 day i used xentry and worked fine. -1 hour later try another go on xentry and receive this internal error -i delete xentry key and try again. -Now xentry small screen goes to load but then closes before it opens. -Now startkeycenter goes to load but closes before opens. DAS, WIS, EPC, HHT, everything else is working fine. It cannot be anything to do with addons, because it was working fine before!. However i now installed ALL addons and still i got this problem. XENTRY + STARTKEYCENTER just flash then close. They do not stay open. I think this is a common problem, because i had it when i installed 03.2016 and i had exactly the same problem before i give up on it. It is some fix need to be done. Who has it? XENTRY INTERNAL ERROR: (3.824)-3.206 - EASatlanta - 01-19-2017 I had the same problem man... I'll rack my brain try to help you in a little Sent from my iPhone using Tapatalk RE: XENTRY INTERNAL ERROR: (3.824)-3.206 - j4g3d - 01-19-2017 (01-19-2017, 07:00 PM)EASatlanta Wrote: I had the same problem man... I'll rack my brain try to help you in a little I think maybe java issue or/and virus/trojan. RE: XENTRY INTERNAL ERROR: (3.824)-3.206 - EASatlanta - 01-19-2017 (01-19-2017, 10:11 PM)j4g3d Wrote:(01-19-2017, 07:00 PM)EASatlanta Wrote: I had the same problem man... I'll rack my brain try to help you in a little I remember now, same thing. it was something wrong with startkey center, I had to delete and reinstall. are you using rocicante's self-extracting installers? or manually replacing startkey center |
