XENTRY Problem - Printable Version
+---- Thread: XENTRY Problem (/Thread-XENTRY-Problem--120059)
XENTRY Problem - MD20 - 01-18-2017
Hello all, I recently bought a SD Connect unit of ebay (I know not the best idea) but I needed it fast so I gave it a go. It's a SDconnect C5 (seems like a C4 unit in a C5 housing). Anyways, I have this really weird problem when ever I go to SCN coding tab in DAS. It gives this error:
Uploaded the pic here = http://imgur.com/a/mtMnd
The top part is in english and the lower section in german. The lower section says:
"While downloading the file a error occured.
Possible problems and solutions:
XENTRY is closed and needs to be restarted."
I used the SD Connect last year of a friend of my dad and when ever I went on to scn coding tab I could code and change stuff there (it was all offline). But the seller told me it is online only and I need account? Is this true? Can I change that somehow?
Also another problem:
When ever I want to start XENTRY I have to set the date and time back to 05.09.2016 or something. Is there a fix for that?
All answers will get a thanks and the comments with tutorials or something like that will get +1 rep
Cheers!
RE: XENTRY Problem - anonimo - 01-18-2017
Look, i think it is not a problem of your sdconnect. i think its all a software problem.
RE: XENTRY Problem - sigaik - 01-18-2017
(01-18-2017, 02:44 AM)MD20 Wrote: Hello all, I recently bought a SD Connect unit of ebay (I know not the best idea) but I needed it fast so I gave it a go. It's a SDconnect C5 (seems like a C4 unit in a C5 housing). Anyways, I have this really weird problem when ever I go to SCN coding tab in DAS. It gives this error:
Cheers!
Yes you can use offline and here you have it!
http://mhhauto.com/Thread-DAS-PKW-SMART-Transporter-Offline-Programming-2014-2015-2016-Tested-and-updated?pid=745739#pid745739
RE: XENTRY Problem - EASatlanta - 01-18-2017
This is a software issue... SCN coding is online coding.
What exactly are you trying to do?
RE: XENTRY Problem - KriyenKPp - 01-18-2017
i also used my star after a long period and unable to open xentry. further to that there is a padlock that remains locked with a number 21. last time i used it , everything worked
RE: XENTRY Problem - viktor - 01-18-2017
What version of XDOS you use? If 03/05/07.2016?
Try to change SDflash folder on SDFlash from new release of XDOS 12.2016
Or use offline fix in link upper.
RE: XENTRY Problem - EASatlanta - 01-19-2017
(01-18-2017, 09:23 AM)KriyenKPp Wrote: i also used my star after a long period and unable to open xentry. further to that there is a padlock that remains locked with a number 21. last time i used it , everything worked
I'm sorry but you aren't being clear what is wrong with your xentry.
Can you diagnose a car?
When do you get the error?
RE: XENTRY Problem - MD20 - 01-21-2017
Sorry guys for the late reply. I was suuper bussy and in a few hours I got my birthday to celebrate so I will probably get back to this thread on sunday! I will try out the offline fix shared by @ sigaik and if it works out I will either report back positively or ask for more help Smile Thanks for the amazing support! Cheers
