HHT Switch ignition on trouble - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: HHT Switch ignition on trouble (/Thread-HHT-Switch-ignition-on-trouble) Pages:
HHT Switch ignition on trouble - wolcar - 01-19-2017 Hi, I have installed Xentry 09/2016 And I have this trouble in HHT with Mercedes Vito
RE: HHT Switch ignition on trouble - dinho - 01-19-2017 I cant see image RE: HHT Switch ignition on trouble - wolcar - 01-19-2017 (01-19-2017, 04:10 PM)dinho Wrote: I cant see imageTry now HHT Switch ignition on trouble - EASatlanta - 01-19-2017 This seems a problem with the car... you have any other HHT cars to test? Try launching from PKW only? Sent from my iPhone using Tapatalk RE: HHT Switch ignition on trouble - roma5000 - 01-19-2017 "Hi, I have installed Xentry 09/2016 And I have this trouble in HHT with Mercedes Vito" I had two times similar problem. One time fuse was broken, second time it was an connector issue on the car. RE: HHT Switch ignition on trouble - wolcar - 01-19-2017 I have testet with Bosch esitronic and identify the car RE: HHT Switch ignition on trouble - roma5000 - 01-19-2017 (01-19-2017, 05:13 PM)wolcar Wrote: I have testet with Bosch esitronic and identify the carso far as I know, Bosch don't use the terminal 15 status. For Bosch is enough to have terminal 30 on the socket. RE: HHT Switch ignition on trouble - pushek - 01-28-2017 In Vito W638 was 2 types of diagnostic socket. OBDII and 38-pin round socket. From which year is your Vito? RE: HHT Switch ignition on trouble - tsuko - 01-28-2017 Same problem with me ---> http://mhhauto.com/Thread-SD-Connect-2016-dont-read-W168-W638-W903-chassis I think that problem is in bad instaled/cracked/ software.Also have tryed to read from first w163 2l 1997 year dont exist in software i dont know what is happening . . . Is this Soft or hardware problem.If i'm write you should not read too these W168-W638-W903-chassis Maybe this will help ---> ? http://mhhauto.com/Thread-Xentry-OpenShell-XDOS-HHT |
