Star Diagnosis Language Change - not Work - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Star Diagnosis Language Change - not Work (/Thread-Star-Diagnosis-Language-Change-not-Work) |
Star Diagnosis Language Change - not Work - genesis2002 - 01-19-2017 Hello, I have to change on a probesystem the system language of star diagnosis. I have the winxp MUI pack installed and in the SKC.properties file changed the language to German (en). But before I found this "trick" here in the forum, I've tried some. After the restart, the system language was German. ![]() Now I have tried it with the working star diagnosis system. Winxp MUI pack installs, SKC.properties in DE changed - reestart but without success. The system is still in english. (Xentry and DAS are in German only the system language of star not) Facts: WinXP SP3 English MUIPack English, Xentry 12.2015 (no XDOS). The system works. Just not the language change. Winxp German - OK Xentry German - OK DAS - German - OK Star Diagnosis - Englisch - f*ck ![]() Would have an idea? Thank you genesis RE: Star Diagnosis Language Change - not Work - Rocinante - 01-20-2017 Xentry and DAS are Star Diagnosis... Can you post a picture? RE: Star Diagnosis Language Change - not Work - genesis2002 - 01-20-2017 Thx for help ![]() Star Diagnosis System start: ![]() SDNC English: ![]() SKC English: ![]() Version info: ![]() Changed SKC.properties (2x at Drive E and F): ![]() Xentry de: ![]() DAS de: ![]() 1. I install Win xp SP3 MUI Language Packs (German) (WinXP speak German )2. I changed the SKC.properties -> language = de (or DE it´s the same resultat only english) With grateful greetings genesis RE: Star Diagnosis Language Change - not Work - Rocinante - 01-20-2017 Why is this bothering you? Once the system is up and running, you will never need these.. just use your Xentry and DAS and go fix cars!!!
RE: Star Diagnosis Language Change - not Work - DBmhh - 01-21-2017 If it really bothers you, reinstall DAS/Xentry and choose German language. Those support applications will follow the installation language. Some, if most can be changed afterwards too but it isn't equally simple, at least I'm not aware of a simple parameter change or something similar. RE: Star Diagnosis Language Change - not Work - Anturage - 01-21-2017 There is ini file in UserData where you can change system language. All StarDiagnosis related applications will change language at once after restart. userdata\config\Xentry\GlobalUserSettings.properties RE: Star Diagnosis Language Change - not Work - DBmhh - 01-21-2017 (01-21-2017, 01:16 PM)Anturage Wrote: There is ini file in UserData where you can change system language. But this only changes the language for the applications that the OP already figured out? I understand he wants to change all the support applications too, like Star Utilities, SDnetControl, the startup text etc. etc. RE: Star Diagnosis Language Change - not Work - genesis2002 - 01-23-2017 (01-21-2017, 08:52 PM)DBmhh Wrote:(01-21-2017, 01:16 PM)Anturage Wrote: There is ini file in UserData where you can change system language. Thanks for the answers, Yes, I will change Star Utilities, SDnetControl, the startup text etc. It bothers me, I have managed to convert it to German on a non-functioning system (test system). I changed some settings in the ini files and after the restart was startup, keycenter and sdnc in German. Unfortunately I have on this day very many other ini files also changed to try a lot now, I unfortunately no longer which. ![]() I have even tried in the registry to change the default language. without success. Sure to re-install would be the easiest way out but it would be interesting to find another away. ![]() Thank you genesis |
