Mercedes W203 need help - Printable Version
+---- Thread: Mercedes W203 need help (/Thread-Mercedes-W203-need-help)
Mercedes W203 need help - darox2005 - 01-21-2017
Lads i have problem with sound system Comand Bose no sound , i checking faults and problem is optical line but i not sure witch component will be give problem i making screen shot for for Faults also i try buy juction for optical wire for testing all components but i cant find i ring to MB dealer in Poland but he said, we dont have , I am grateful for the suggestions and help in this topic.
[attachment=164900]
RE: Mercedes W203 need help - Kaluluka - 01-21-2017
First one after the COMAND is to be checked......
RE: Mercedes W203 need help - darox2005 - 01-21-2017
[quote='Kaluluka' pid='868191' dateline='1484942547']
How need to be checking ?? i dont have junction wire ,
What module is after COMAND? Usualy on benz it is UCI...
Check for red lights on optics...
Check optical ring coding on COMAND and if it is untouched, original coding it will tell you coded units after COMMAND...
i will check all the rest module tomorrow i was check only line from comand and from sound booster all blinking red line both side
RE: Mercedes W203 need help - Rocinante - 01-22-2017
the fault in Position 1 means count backwards on the ring.. look at the actual values under component list.. the component at position 1 error means the last component on the ring sent a signal to the Comand that it didn't get a signal from the component before it.. it could be the component before it, the fiber optic line or the receiver in component 1 Smile
RE: Mercedes W203 need help - darox2005 - 01-22-2017
the car back to me tomorrow one more time i check all component ,and check coding position , someone can be send website in Europe where i can buy junction wire for optical wire or optical connector line for MB
Thanks for any help
Smile
A cheap easy way to bypass the optical part of a module is to use a piece of vacuum hose and put the transmit and receive fibers in each end until they almost touch..
RE: Mercedes W203 need help - xzt - 01-23-2017
Hy mate !
some problem was on the tuner in the left rear trunk if you say that you have sitem bose !
