Vediamo Programstart - Printable Version
+---- Thread: Vediamo Programstart (/Thread-Vediamo-Programstart)
Vediamo Programstart - spark - 01-23-2017
Vediamo takes much toooooooooo long for Programstart.
After the Server is started I get a error information in the headline (no response).
After waiting 2Minutes or so the Program runs.
Is this normal? I use 2Gb Memory and 32 bit win7
Can anybody help me with a hint
Spark
RE: Vediamo Programstart - laco210 - 01-23-2017
Where you have saved and how much cbf files? If in VediamoData folder then program read this files during start.
RE: Vediamo Programstart - spark - 01-23-2017
The files are saved under Documents in a separat folder named cbf.
I didn't count the cbf's
RE: Vediamo Programstart - Dollsburg - 01-23-2017
Remove the CBF,CFF and CCF form programdata and see if it loads up faster! Usually this is the case when you extract the 2/3.sumthing GB ziped files from the download to C:\\programdata\vediamo\VediamoData! If it starts faster without the CBF/CFF/CCF and VSB (if you have), then load them from a separate directory based on your system needs and requirements for ecoute system select.
The average requirements for Win7 is usually,1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor,1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit),16 GB available hard disk space (32-bit) or 20 GB (64-bit)
So you system is very close to these tolerances, so you if you have to make do with what you got use it strategically, bearing in mind that for ecoute to start it has to load up the cbf & vsb for you to choose the system and yet your PC has low computing power!
You can get a faster machine like a 2.8Ghz Quadcore/ i7, 8GB Ram, and a 128SSD for fast and responsive runs! These Diag apps/software need serious computing power if you know what u r doing!
You can also downgrade your OS to Win XP SP3 and use an SSD for improved performance. The choice is yours.
I have files in VediamoData folder but in separate folders inside and I have no problem with starting system.
[attachment=165176]
Dollsburg gave me the hint.
The problem is solved.
I still use a Clone version (Full system) not on a simmilar PC. So the mainproblem is the Hardware which does not fit to the cloned system.
Windows installation is adapted to the particular hardware it was installed on. Programs that require activation may cause a problem. If you clone a drive you'll have the same Windows license running on two computers (OS Manufacturer doesn't like that) while not using the license you paid for when you bought the new PC. So there will be very many conflicts running in the background if a cloned drive for a Dell D630 is used on a fujitsu siemens amilo pro! Local installations are far much more superior than cloned stuff which seem to be an easier copy paste solution!
