Smart 451 TCU Problem. - Printable Version
+---- Thread: Smart 451 TCU Problem. (/Thread-Smart-451-TCU-Problem)
Smart 451 TCU Problem. - jakubo - 01-27-2017
Hello
I have a problem with smart 451 2008 mhd
das version 07/2014 vediamo 4.02.02
Yesterday i changed variant coding in engine ecu to activate cruise control. coding changed ok but cruise control not working - but it is not a problem.
Problem is that when i came to car today i had no battery was fully drained (i forgot to connect it yesterday). Battery changed, i tried to start engine but i have no gear on display. i connected SD to car and in TCU there is no errors. only errors that i have is CAN communication problem in ME, cluster, sam, and abs to TCU. I can connect to TCU. but in ecu identification i see that software version is BOOT and there is no vin stored in TCU.
So i think that is problem with flash which is corrupted. I tried to reflash it with das offline but it gives me error vedoc cant find correct file for this car. I also tried to flash TCU with vediamo with manualy selected file but after 15sec and 0% it gives error 'flashing is broken'.
How to reflash this ecu or back it to life?
RE: Smart 451 TCU Problem. - audiomeca - 01-27-2017
Hello
if vediamo not run, (try with 14v power) only can try with ktag but not by obd only on table
About tempomat
2008 car not have fitted the 3 wiring from steering to meg unit, and 2008 cars not can fit tempomat from factory only euro 5 cars from 2010 (not diesel) can fit.
meg for tempomat have diferent hardware and diferente software not only coding!!!
good luck
