question about immo off merchdes c CLASS Sim4 LE - Printable Version
+---- Thread: question about immo off merchdes c CLASS Sim4 LE (/Thread-question-about-immo-off-merchdes-c-CLASS-Sim4-LE)
question about immo off merchdes c CLASS Sim4 LE - Rodja63 - 01-29-2017
Hi
I have a friend how have buy a car a merchdes c200 2002..
And The owner of this car have change the ecu Because of
water damage. And the engine want not crank and start. So i thinking it have to do with The immo..This ecu dont have eprom for The immo.
I have check inside and found flash AM29F400BB. If I understad it corect i need a flash with immo off virgin file to start The car..I am new when it
Comes to programming ecu..I have ktag v2,13 can i use this to fix it.
Did some one have a flash dump for immo off.. in this case whill it Bee exactly the same software in The flash with out immo. As orginal
Can i do it from obd or on the table .. If i understand it corect i shod read out the file from the ecu and save it as a copy. And take the dump to the used ecu. .Or If I place a dump from the ecu on this forum.Maybee some one can fix this filé with immo off... The most easy whay to do it have been If I have The water damage ecu and only swap flash directly..
But no i am not so lucky the customer have scrapped the orginal ecu.. How is it when it Comes to immo is it in eprom and in flash software for The car.. Where is the vin code writening in The flash or eprom or cpu.. I am new when it Comes to programming..
What is written in The processor did whe have The vin here....
Vin WDB2037451A209963
HW 02/01
FD 27W01
Q1
5WK9 0410
Motor cod m111-955
HK 163
Merchdes benz c 200
2002.
RE: question about immo off merchdes c CLASS Sim4 LE - mb_port - 01-29-2017
immodata sim4le flash 29f400
swap flash chip or upload dump
RE: question about immo off merchdes c CLASS Sim4 LE - bersch8688 - 01-29-2017
Order Donor ecu with same part number
Swap flash 29f400bb from old ecu in donor ecu with hot air
Car will start and all fine
