Difference TwinB C4 & C3 ? - Printable Version
+---- Thread: Difference TwinB C4 & C3 ? (/Thread-Difference-TwinB-C4-C3)
Difference TwinB C4 & C3 ? - rayriosul - 03-08-2017
hello mates,
i have a simple question but found no answer yet.
what is the real difference between TwinB II C4 and C3??
Both of them are with cable RS 232 seriell
do they have same tookit.ini ??
thanks for your patience
Difference TwinB C4 & C3 ? - fabek - 03-09-2017
They are same construction. Twin C4 has better high voltages support.
RE: Difference TwinB C4 & C3 ? - DBmhh - 03-09-2017
(03-09-2017, 12:56 PM)fabek Wrote: They are same construction. Twin C4 has better high voltages support.
Better compared to which "C3"? I thought the crap C3 clone has the same circuit boards as the Chinese C4 (the flat box). I assume "Twin C4" is the same product?
A proper "C3" clone has the same voltage supply (voltage regulation and regulator circuit heat sink) approach as the original PartD devices had. No problem with 28.8 V trucks there, clone or original.
Perhaps this Twin C4 has a different approach from the two, better than the crap C3 but not any better than the proper C3 clone. Does it have a modified 24 V to 12 V pre-regulator, perhaps a switching supply instead of the old-fashioned linear regulator?
RE: Difference TwinB C4 & C3 ? - pesona - 03-09-2017
(03-09-2017, 01:27 PM)DBmhh Wrote: ... Does it have a modified 24 V to 12 V pre-regulator, perhaps a switching supply instead of the old-fashioned linear regulator?
what an awesome idea mate. but do someone ever make a selfmade 24v to 12 v pre-regulator? for partD or/and for SDConnect?
SDconnect already has a high efficiency switching power supply (if built with good components). Perhaps better to use the C3 with 12 V cars only if it is not made for 24 V. Only a few need 24 V diagnosis capability and the few can purchase a good C4 or a good C3.
I'd still be interested if someone has built a step down regulator. Should be built to work with 12 V cars too, even when their battery is low. Could be easier to feed the 5 V circuitry directly instead of replacing the in-built 24 to 12 V pre-regulator?
