221 KI White Display Problem - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: 221 KI White Display Problem (/Thread-221-KI-White-Display-Problem) Pages:
221 KI White Display Problem - Vandale17 - 03-09-2017 Hello everyone Sorry for my bad german i come from germany: P It is about a w221 s500 bj 2005 first time my colleague have display flicker then totally failure whereby I think that the self what done .. I myself own the xentry c3 vediamo and eepro station ..Link with KI goes that says however directly software faulty Have a picture attached perhaps one of you knows what to be there Can many thanks already times RE: 221 KI White Display Problem - Kaluluka - 03-09-2017 Hi! I can help..... Moin! Ich kann helfen..... RE: 221 KI White Display Problem - Vandale17 - 03-09-2017 I'm waiting for suggestions ich warte auf Vorschläge
RE: 221 KI White Display Problem - Kaluluka - 03-10-2017 For Suggestion we need info from diagnostic: you have faulty hardware or software. Session from diagnostic of IC will clarify whats wrong. RE: 221 KI White Display Problem - musta60 - 03-10-2017 dash file is faulty put other file all ok RE: 221 KI White Display Problem - kin1830 - 03-10-2017 get a used one and be sure its the same part number and change eeprom RE: 221 KI White Display Problem - Vandale17 - 03-11-2017 I can unfortunately the photo does not post does not work but in vediamo is: KI221-BootV12E0 D602:ECU Application software Code 2 Is missing or is faulty RE: 221 KI White Display Problem - musta60 - 03-11-2017 with vediamo its hard do you have another dash put a file in it eveything will be ok 221 KI White Display Problem - benzsport - 03-12-2017 Display is in bootmode. Take Steuergeräteprogrammierung with DAS and flash the right files. DAS Choice the right ones. I can fix it too. With Vediamo works great too, but you must know which files you need. |
