Abrutis PassThru for DAS Xentry - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Abrutis PassThru for DAS Xentry (/Thread-Abrutis-PassThru-for-DAS-Xentry) Pages:
Abrutis PassThru for DAS Xentry - webmaster - 01-12-2013 Hi Folks, I want to install DAS Xentry PassThru Driver. I got the following Error: Cannt write file 'Slave.ini'. Make sure it is not read only. I already checked the file. Its not read only. Whats could be the problem? P.S Im using Version 7-2012 Best regards
RE: Abrutis PassThru for DAS Xentry - webmaster - 01-12-2013 Problem Solved ![]() The Problem was in the path. I created New DAS/bin Folder in C:programme Then Copy The Driver Folder from DAS/bin ( F: ) to the new path ==> apply the passThru installation. Copy Back the Driver Folder ( C: ) to F:programme/Das/Bin Back up ur original folder before you do so ![]() Best regards. RE: Abrutis PassThru for DAS Xentry - sozberk - 01-12-2013 pplease explain sir, how can I use this tool vith das and xentry, which tool buy, from where and price? RE: Abrutis PassThru for DAS Xentry - webmaster - 01-12-2013 (01-12-2013, 03:26 AM)sozberk Wrote: pplease explain sir, how can I use this tool vith das and xentry, which tool buy, from where and price? http://www.abritus72.com/ Best regards
RE: Abrutis PassThru for DAS Xentry - nguyennhatquang - 01-13-2013 so that mean it support any kind of J2534. can we use Cardag with it? or only abritus will work? RE: Abrutis PassThru for DAS Xentry - webmaster - 01-18-2013 (01-13-2013, 06:33 AM)nguyennhatquang Wrote: so that mean it support any kind of J2534. can we use Cardag with it? or only abritus will work? Check in there official site and contact there support. Best regards
RE: Abrutis PassThru for DAS Xentry - TizWaz - 04-07-2014 (01-18-2013, 10:07 PM)webmaster Wrote:(01-13-2013, 06:33 AM)nguyennhatquang Wrote: so that mean it support any kind of J2534. can we use Cardag with it? or only abritus will work? Hello Can i ask what version you installed ? RE: Abrutis PassThru for DAS Xentry - mattydr67 - 04-07-2014 As I know the lastest Das/Xentry that support full passthru is 01/2011 I'm using 11/2010 in vmware Only das I'm useing it no xentry Good luck RE: Abrutis PassThru for DAS Xentry - ajpds - 05-13-2015 (01-12-2013, 02:01 AM)webmaster Wrote: Problem Solved hello I not foud the driver folder in f: ..... please help regards |
