IS THERE ANY IDLE SPEED ADJUSTMENT FUNCTION ON TECHSTREAM? - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Toyota, Lexus, Honda Discussions. (https://mhhauto.com/Forum-Toyota-Lexus-Honda-Discussions) +---- Thread: IS THERE ANY IDLE SPEED ADJUSTMENT FUNCTION ON TECHSTREAM? (/Thread-IS-THERE-ANY-IDLE-SPEED-ADJUSTMENT-FUNCTION-ON-TECHSTREAM) |
IS THERE ANY IDLE SPEED ADJUSTMENT FUNCTION ON TECHSTREAM? - DANITO - 07-27-2017 Hi mates Is there any idle speed adjustment funtion on Toyota Techstream? RE: IS THERE ANY IDLE SPEED ADJUSTMENT FUNCTION ON TECHSTREAM? - david_dung - 07-29-2017 (07-27-2017, 02:54 AM)DANITO Wrote: Hi matesThere is not any idle speed adjustment function on Toyota Techstream, but there is a reset memory function on this after cleaning thorttle assembly.
RE: IS THERE ANY IDLE SPEED ADJUSTMENT FUNCTION ON TECHSTREAM? - DANITO - 07-30-2017 Which MENU has the 'reset memory function' please? RE: IS THERE ANY IDLE SPEED ADJUSTMENT FUNCTION ON TECHSTREAM? - david_dung - 07-31-2017 [quote='DANITO' pid='1016624' dateline='1501395730'] Which MENU has the 'reset memory function' please? [/quodujng Apply 2012- RE: IS THERE ANY IDLE SPEED ADJUSTMENT FUNCTION ON TECHSTREAM? - tientran909 - 11-09-2017 disconnect the battery drive for 15min in city traffic stop. RE: IS THERE ANY IDLE SPEED ADJUSTMENT FUNCTION ON TECHSTREAM? - kangk81 - 04-19-2021 (07-31-2017, 07:53 AM)david_dung Wrote:(07-30-2017, 11:22 AM)DANITO Wrote: Which MENU has the 'reset memory function' please? I'm gonna got OOT for a bit. From your screenshot, your techstream menu has the "VIN" function in the utility menu while mine doesn't. Is it a function of the different locales or is it because I'm using the knockoff MVCI cable? RE: IS THERE ANY IDLE SPEED ADJUSTMENT FUNCTION ON TECHSTREAM? - abdulss - 05-11-2021 Enter check mode then exit RE: IS THERE ANY IDLE SPEED ADJUSTMENT FUNCTION ON TECHSTREAM? - shadab - 05-12-2021 Systems > Engine and ECT > Utility > Reset Memory. |
