W212 colored cluster in W204 - Fuel and light switch not available - Printable Version
+---- Thread: W212 colored cluster in W204 - Fuel and light switch not available (/Thread-W212-colored-cluster-in-W204-Fuel-and-light-switch-not-available)
W212 colored cluster in W204 - Fuel and light switch not available - rabaukee - 08-20-2017
Hey guys,...
got a problem I cant get behind easily so I better ask here. I put a W212 colored cluster into my W204 which had monochrome until then. It is all good after fitting the codings as good as possible to the old one. But I still got two serious problems here:
1) light switch does not seem to be regocnized (light is always on, even on switch off, and cluster is complaining light is on when leaving the car).
2) Fuel state does not seem to be read by cluster. There is no fuel information at all in the cluster...
Any hint what exactly is effecting this? I pulled all the codings over manually from the monochrome cluster... 533
Thanks you dudes! Fing32
RE: W212 colored cluster in W204 - Fuel and light switch not available - Powerpaul - 08-20-2017
Ask user "bjoern" he helped me out with this problem with same problem on my w204 cluster with facelift cluster retrofit.
RE: W212 colored cluster in W204 - Fuel and light switch not available - rabaukee - 08-20-2017
Thanks. Any hint whats the cause? The cluster is missing messages from engine control unit and rear SAM.
Updated rear SAM lately, so I doubt old SW on it is the cause (well it was 2012 database). I might have missed something while setting up the cluster,...
It will likely only be a setup on the cluster to make it feel comfortable with the new compound of ecus... did not find it right away.
Any help well appreciated.
As I remember he told me it´s a bug in early 204 rearsam. But I don´t remember how to fix it correctly.. :-/
That is a good hint. But how to fix a bug Wink With SW update I guess...
Fixed the fuel prob thanks to powerpaul... light switch problem still left... :-/
RE: W212 colored cluster in W204 - Fuel and light switch not available - MegaCar - 08-20-2017
(08-20-2017, 07:20 AM)rabaukee Wrote: Fixed the fuel prob thanks to powerpaul... light switch problem still left... :-/
Ho,
Contact this guy
http://mhhauto.com/User-Benzdriver23
RE: W212 colored cluster in W204 - Fuel and light switch not available - Bjoern - 08-21-2017
(08-20-2017, 01:23 AM)rabaukee Wrote: Hey guys,...
There is more information needed.
What CFF files are on cluster?
Also put save of coding from the cluster here.
RE: W212 colored cluster in W204 - Fuel and light switch not available - rabaukee - 08-21-2017
Here's the software currently running on it:
Code:
    Sachnummer      Version         Lieferant       Status      geflasht  durch
Hardware     2129014102      12/09.00        VDO             -           -         -
SW Block #0     2049022903      12/08.00        VDO             valid       255-255-2 Re FFFFFFFF
SW Block #1     2049023003      12/08.00        VDO             valid       255-255-2 Re FFFFFFFF
SW Block #2     2049023303      12/08.00        VDO             valid       255-255-2 Re FFFFFFFF
SW Block #3     2049022803      12/08.00        VDO             valid       255-255-2 Re FFFFFFFF
SW Block #4     2049023203      12/08.00        VDO             valid       255-255-2 Re FFFFFFFF
Don't have the current parameters set available, will put it here later. Only the one when I bought hte cluster, but I already did some parameter changes according to the old cluster and to the needed setup here.
Anyway, for the daylight problem (light always on) I suspect these parameters in VCD_06/VCD_07 to be responsible for it:
Code:
Tagfahrlicht motorlaufabhängig (Menu_Daylight_Running_light)     vorhanden   03UZ
and/or
Code:
Fahrlicht (Daylight_FactDef)     Dauer   FFPF
Fahrlicht motorlaufabhängig (Daylight_Running_Light_FactDef)     Dauer   FFPJ
Thanks for any hint guys. Drive
//EDIT: As the last two parameters are from VCD_07 and therefore user settings,... the daylight running "problem" is probably caused here. If so, it is not a problem, I was just to blind to see, so that would be "stupid me" Big Grin But I will find out later.
//EDIT2: Solved. As often the problem is sitting in front of the PC/Car. It was the drivers menue settings that kept the light on. For that fuel and daylight problem explained here I am ok now. Thanks.
