VAG EEPROM Programmer Setup 119 FREE - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Airbag, Dash, ECU, IMMO. (https://mhhauto.com/Forum-Automotive-Airbag-Dash-ECU-IMMO) +--- Thread: VAG EEPROM Programmer Setup 119 FREE (/Thread-VAG-EEPROM-Programmer-Setup-119-FREE) |
VAG EEPROM Programmer Setup 119 FREE - abdo0099 - 03-26-2013 ![]() ![]() VAG EEPROM Programmer Setup 119 is free for all ![]()
RE: VAG EEPROM Programmer Setup 119 FREE - saad_vw - 03-26-2013 good software witch cable can i use and where can i buy it thanks RE: VAG EEPROM Programmer Setup 119 FREE - doktorabg - 03-26-2013 (03-26-2013, 10:31 AM)saad_vw Wrote: good software You can use normal KKL interface(blue) from old Vag-Com RS-232 ist the best but USB to Serial is good too [attachment=19295] RE: VAG EEPROM Programmer Setup 119 FREE - wyz1056 - 03-26-2013 k-line is can work this soft! RE: VAG EEPROM Programmer Setup 119 FREE - doktorabg - 03-26-2013 (03-26-2013, 04:50 PM)wyz1056 Wrote: k-line is can work this soft!
RE: VAG EEPROM Programmer Setup 119 FREE - mabaragh - 02-22-2014 hello evry body I want methd for use vag eprom progrmmer 1.19 with vag 409 kkl usb i have problem wen tuse vag eprom it deos not work please helpppppppppppppppppppppppppp RE: VAG EEPROM Programmer Setup 119 FREE - MK2-VRT - 02-22-2014 No screaming..! What does not work ? He give a error ? Do you select USB or COM ? RE: VAG EEPROM Programmer Setup 119 FREE - drcoxx - 07-30-2014 Hi... can i use vag eeprom reader with vcds cable?? RE: VAG EEPROM Programmer Setup 119 FREE - doktorabg - 07-30-2014 (07-30-2014, 09:00 PM)rrdiagnostic Wrote: Hi... can i use vag eeprom reader with vcds cable?? Yes, you can but first run VCDS go to settings and make HEX-CAN USB Interface to normal KKL, there is setup for that. Thanks to member Yoshimura. Наздраве Приятелю! |
