need login code 1.8t me7.5 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Airbag, Dash, ECU, IMMO. (https://mhhauto.com/Forum-Automotive-Airbag-Dash-ECU-IMMO) +--- Thread: need login code 1.8t me7.5 (/Thread-need-login-code-1-8t-me7-5) |
need login code 1.8t me7.5 - tobi4711 - 11-18-2017 hi i have 2 eeproms and i need the login code thank you for your help RE: need login code 1.8t me7.5 - l0x2 - 11-18-2017 8812 (2) file is wrong login is 65535 (FF FF) RE: need login code 1.8t me7.5 - Freezzby - 11-18-2017 Hi yes login in first dump login 8812 so it's 08812. RE: need login code 1.8t me7.5 - tobi4711 - 11-19-2017 for a used speedometer I need the login code of the speedometer and ecu RE: need login code 1.8t me7.5 - ladadens - 11-19-2017 its the same log in. |
