Insert CD labeled 'Star Diagnosis Software' - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Insert CD labeled 'Star Diagnosis Software' (/Thread-Insert-CD-labeled-Star-Diagnosis-Software) |
Insert CD labeled 'Star Diagnosis Software' - Fouad - 05-02-2013 Hello MHHATUO members
I am facing a problem as in the following picture, ![]() I need to copy some files from DVD but which files and to where thanks in advanced ![]() Regards RE: Insert CD labeled 'Star Diagnosis Software' - j4ru - 05-02-2013 In my case problem was in files : "F:\Programme\DAS\SDflash\Release\sdflash.ini" check paths to files , good one look like this : Quote:[Directory] and file "F:\Programme\DAS\SDflash\Release\PKW\profi_cd.ini" copy this file form second install DVD . P.S. Chech other ini files if there are path to files goes to "F" drive not "C" Or Flash file to module in DAS was older than flash in module ( small chance ), but in Your screenshot DAS ver is 01/2013 ( and maybe installed on Dell D630 )and with this version I have same problem.Best Regards j4ru RE: Insert CD labeled 'Star Diagnosis Software' - Rocinante - 05-02-2013 In 01/2013 the path is F:\Programme\SDflash... it changed a few versions ago... If its not there, it didn't install properly... RE: Insert CD labeled 'Star Diagnosis Software' - j4ru - 05-02-2013 (05-02-2013, 07:16 PM)Rocinante Wrote: In 01/2013 the path is F:\Programme\SDflash... it changed a few versions ago... Yes but when I install this version of StarDiagnosis in ini files was wrong path ( bug maybe? ). RE: Insert CD labeled 'Star Diagnosis Software' - Rocinante - 05-03-2013 Maybe.. On the newer versions there is a folder on the install DVD that has a setup.exe that you can run to install just the SDflash... I think it's \stardiag\SDflash\setup.exe RE: Insert CD labeled 'Star Diagnosis Software' - Fouad - 05-03-2013 thanks a lot guys, I found that this directory is EMPTY F:\Programme\DAS\SDflash\Release I will try to copy the files and folders from "F:\Programme\SDflash" TO "F:\Programme\DAS\SDflash\Release" and look to what happened next RE: Insert CD labeled 'Star Diagnosis Software' - Rocinante - 05-04-2013 It should be empty.. all the files should be in f:\Programme\SDflash... Your software should be looking in \programme\SDflash.. if not, then its configured wrong.. ![]() Does your SDflash.ini in F:\Programme\SDflash\Release look like this?? [Directory] PKW=F:\Programme\SDflash\Release\PKW LKW=F:\Programme\SDflash\Release\LKW Transp=F:\Programme\SDflash\Release\Transp smart=F:\Programme\SDflash\Release\SMART Unimog=F:\Programme\SDflash\Release\UNIMOG FUSO=F:\Programme\SDflash\Release\FUSO BharatBenz=F:\Programme\SDflash\Release\BharatBenz Also, are you using a modified DAS32r2.exe??? I don't think you can perform flashing with this in place.. you must use Xentry and let it start DAS with the original .exe file RE: Insert CD labeled 'Star Diagnosis Software' - hagop - 05-04-2013 hi I had the same problem and this solved my problem there is a fix for DAS OFFLINE PROGRAMING inbetrieb is the name of this file I used and all worked http://mhhauto.com/Thread-DAS-Offline-Programing?highlight=DAS+OFFLINE+PROGRAMING RE: Insert CD labeled 'Star Diagnosis Software' - Fouad - 05-04-2013 (05-04-2013, 12:34 AM)Rocinante Wrote: It should be empty.. all the files should be in f:\Programme\SDflash... it is the same as above I will try tomorrow and let you know ![]() thanks |
