fault code delete - Printable Version
+--- Thread: fault code delete (/Thread-fault-code-delete)
fault code delete - masterbfish - 02-07-2018
H all,
Can someone please delete these 2 fault codes.
Vehicle: VW Golf V GTI
ECU Type: Bosch MED 9.1
004248 (P1098) - Intake manifold valve position sensor
012691 (P3191) - Intake runner control - open stop outside of valid range
Thanks in advance
RE: fault code delete - rosi1000rr - 02-08-2018
(02-07-2018, 01:44 PM)masterbfish Wrote: H all,
Thanks in advance
Try this solution
BR
RE: fault code delete - masterbfish - 02-08-2018
Thanks in advance
Try this solution
BR
Thank you for your solution.
There is still this fault left.
Can you delete it?
RE: fault code delete - masterbfish - 02-09-2018
can no one delete this fault code?
