How to create WIS-ASRA EPC shortcuts on desktop on Xentry 122017 never expire - Printable Version
+---- Thread: How to create WIS-ASRA EPC shortcuts on desktop on Xentry 122017 never expire (/Thread-How-to-create-WIS-ASRA-EPC-shortcuts-on-desktop-on-Xentry-122017-never-expire)
How to create WIS-ASRA EPC shortcuts on desktop on Xentry 122017 never expire - plore90 - 07-29-2018
Hello at all!
Here my cent's for create WIS-ASRA and EPC shortcut on desktop on Xentry XDOS 12.2017 (and later ?) never expire (error 462 EWA Session Token Expired)
1) GO TO Control Panel then to JAWA CONTROL PANEL - Temporary Internet Files-View- click on EPC and WIS ICON AND THEN DELETE the two applications and close JAVA CONTROL PANEL.
2) Run as administrator EWA ADMIN TOOL, go to Server Tab and Stop EWA server and Stop EWA database. Close EWA ADMIN TOOL. Go to C:\Program File\ or Program Files (x86) \ EWA \ config \ directory and locate the file um_cfg.xml and make a security copy.
open with a XML editor or Notepad and locate the two rows: <PARAMETER name="tokenActiveMinutesAfterStart">30</PARAMETER> and
change 30 value to -1 and <PARAMETER name="tokenActiveMinutesAfterReinitialization">480</PARAMETER> and change 480 value to -1
Close and save the file.
3) Run as administrator EWA ADMIN TOOL and go to SERVER TAB and click on Restart EWA Server and Start EWA database buttons. Close EWA ADMIN TOOL.
Restart the Pc
4) Open EWA with Internet Explorer and click the EPC button and open EPC application, close and exit the EPC, click the WIS-ASTRA button and open WIS application, close and exit the WIS-ASTRA.
Close and exit from EWA.
5) GO TO Control Panel then to JAWA CONTROL PANEL - Temporary Internet Files-View- click on EPC and WIS ICON and then CLIK INSTALL SHORTCUTS TO SELECTED APLICATION
That's all.....
RE: How to create WIS-ASRA EPC shortcuts on desktop on Xentry 122017 never expire - sherwin1111 - 07-29-2018
This has already been shared 50 times.
RE: How to create WIS-ASRA EPC shortcuts on desktop on Xentry 122017 never expire - HestonDiag - 07-29-2018
I believe I was the first person that posted this solution when the problem came up many years ago. Headbang
RE: How to create WIS-ASRA EPC shortcuts on desktop on Xentry 122017 never expire - beckereurope - 07-30-2018
please put in the FAQ
RE: How to create WIS-ASRA EPC shortcuts on desktop on Xentry 122017 never expire - plore90 - 08-04-2018
(07-30-2018, 03:31 PM)beckereurope Wrote: please put in the FAQ
Mr. Rocinante, can you post in to F.A.Q?
RE: How to create WIS-ASRA EPC shortcuts on desktop on Xentry 122017 never expire - Rocinante - 08-04-2018
12.5 under WIS/ASRA/EPC/EWA help
I need to publish a 2018 version, just been super busy
RE: How to create WIS-ASRA EPC shortcuts on desktop on Xentry 122017 never expire - cloud9atom - 07-29-2021
i used this method step by step exactly now my ewa/epc/wis stopped working, incredible
RE: How to create WIS-ASRA EPC shortcuts on desktop on Xentry 122017 never expire - DBmhh - 07-31-2021
(07-29-2021, 09:22 PM)cloud9atom Wrote: i used this method step by step exactly now my ewa/epc/wis stopped working, incredible
Please post your um_cfg.xml file for review (text format is fine).
RE: How to create WIS-ASRA EPC shortcuts on desktop on Xentry 122017 never expire - cloud9atom - 07-31-2021
No need to, all i did was change the 30 and the 480 to -1 so that the token would not expire after server starts for the shortcut
Tried reinstalling but same shit, the solution that repaired the 404 error i got is the one where i disable my ethernet and wifi from network adapters/device manager, restart, open ewa then enable ethernet and wifi
Edit: I am using WIS 2020 10 and EPC 2018 11, latest versions basically
I copied the original one to desktop, changed it from xml to txt, changed the numbers, revert to xml and replace the original one (ofcourse with other steps from thread)
I would not risk pairing this method with the method from the thread as i don t want to waste again a few hours to be honest, thanks for the help!
