Polo 2018 AW reset steering assist P1609 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: VAG Group VW , Audi, Seat, Skoda, Bentley Discussions. (https://mhhauto.com/Forum-VAG-Group-VW-Audi-Seat-Skoda-Bentley-Discussions) +---- Thread: Polo 2018 AW reset steering assist P1609 (/Thread-Polo-2018-AW-reset-steering-assist-P1609) |
Polo 2018 AW reset steering assist P1609 - hubson - 10-19-2018 Hello. I want to start the steering support after the accident. I've processed the odis. I made adjustments, parameterizations and settings for the kata sensor. The error disappears and then returns. I want to try vcds but I do not have a login. In the attachment autoscan. RE: Polo 2018 AW reset steering assist P1609 - Provag - 10-19-2018 From the diagnostic log seems that your g85 is not functioning well. perform basic setting of the g85 and see in measured values if its in the 0 position when steering wheel is straight. see if the value changes as you turn the steering wheel right or left till the mechanical stop. if you are having the same issue replace the g85 RE: Polo 2018 AW reset steering assist P1609 - hubson - 10-19-2018 The value of the angle sensor sensor does not change. Basic settings also do not pass. RE: Polo 2018 AW reset steering assist P1609 - Provag - 10-19-2018 replace g85 RE: Polo 2018 AW reset steering assist P1609 - hubson - 10-19-2018 The g85 is built into the power steering. Everything is together on the steering column. RE: Polo 2018 AW reset steering assist P1609 - Provag - 10-19-2018 (10-19-2018, 12:04 PM)hubson Wrote: The g85 is built into the power steering. Everything is together on the steering column. uuuuu big trouble RE: Polo 2018 AW reset steering assist P1609 - Bob the builder - 10-19-2018 (10-19-2018, 11:30 AM)hubson Wrote: Hello. I want to start the steering support after the accident. I've processed the odis. I made adjustments, parameterizations and settings for the kata sensor. The error disappears and then returns. I want to try vcds but I do not have a login. In the attachment autoscan. VCDS:44,16 login:17580,04 reset to factory settings. that's all RE: Polo 2018 AW reset steering assist P1609 - hubson - 10-19-2018 Do not accept login 17580. This is the latest polo. RE: Polo 2018 AW reset steering assist P1609 - Garage99 - 10-19-2018 red light and power steering not working? |
