ISTA-D 4.15.23 Standalone / SQLiteDBs 4.15.21 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Software. (https://mhhauto.com/Forum-Automotive-Software) +---- Forum: AUTO Software on Torrent (https://mhhauto.com/Forum-AUTO-Software-on-Torrent) +---- Thread: ISTA-D 4.15.23 Standalone / SQLiteDBs 4.15.21 (/Thread-ISTA-D-4-15-23-Standalone-SQLiteDBs-4-15-21) |
ISTA-D 4.15.23 Standalone / SQLiteDBs 4.15.21 - Spider80 - 12-19-2018 ISTA-D 4.15.23 Standalone / SQLiteDBs 4.15.21 FASTA & HW check disabled. License & regfiles included. SQLiteDBs RU, EN, DE, OTHER torrent. Password ask in PM after pressing and buttons !!!Give me a link on ISTA version for which you need a password. Enable Your PM before asking password !!! Don't ask passwords in thread, commets to my profile or email. ONLY PRIVATE MESSAGE -
RE: ISTA-D 4.15.23 Standalone / SQLiteDBs 4.15.21 - Tonn - 01-27-2019 Can you sent me the password please? Thanks Greetings Ton
RE: ISTA-D 4.15.23 Standalone / SQLiteDBs 4.15.21 - jeroenvg - 02-02-2019 I have a problem with installing: I did everything like in the FAQ. I tried to install on windows 7 and a fresh install of windows 10. Same problem. This is my Log file: 2016-01-31 22:50:28.943 INFO [T] ISTA: [1] ConfigSettings.ConfigSettings() - called 2016-01-31 22:50:28.945 INFO [T] ISTA: [1] ConfigSettings.ConfigSettings() - OperationalMode is ISTA 2016-01-31 22:50:29.394 INFO [T] ISTA: [1] App.StartIstaServices() - Try to start ISTA Services host ... 2016-01-31 22:50:29.410 INFO [T] ISTA: [1] IstaProcessStarter.Start() - called. 2016-01-31 22:50:29.415 ERROR [T] ISTA: [1] App.Init() - Failed to start ISTA: BMW.Rheingold.CoreFramework.WcfCommon.IstaProcessStartException: Manipulation detected. at BMW.Rheingold.CoreFramework.WcfCommon.IstaProcessStarter.CheckSignature(String pathToIstaProcessFile) at BMW.Rheingold.CoreFramework.WcfCommon.IstaProcessStarter.Start[TArgs](String pathToIstaProcessFile, TArgs istaProcessArgs) at BMW.ISPI.IstaServices.Controller.IstaServicesController.StartHost(IDictionary`2 configuration) at BMW.Rheingold.ISTAGUI.App.StartIstaServices(LogCleaner logCleaner) at BMW.Rheingold.ISTAGUI.App.Init() at BMW.Rheingold.ISTAGUI.App..ctor() 2016-01-31 22:50:29.440 ERROR [T] ISTA: [1] ServiceLocator.GetService<T>() - No service registered for type "BMW.Rheingold.CoreFramework.Contracts.IUia". Using default instead. 2016-01-31 22:50:29.440 WARNING [T] ISTA: [1] DialogBase.Init() - Service IUia is not available using UiaNone instead. 2016-01-31 22:50:29.593 WARNING [T] ISTA: [1] DialogBase.DialogBase() - Dialog owner BMW.Rheingold.PresentationFramework.MessageDialog could not be set, because it is invisible. 2016-01-31 22:50:29.596 INFO [T] ISTA: [1] PresentationFramework.PresentationFramework() - ctor called. 2016-01-31 22:50:29.708 INFO [T] ISTA: [1] CoreFramework.CoreFramework() - ctor called. 2016-01-31 22:50:29.942 INFO [T] ISTA: [1] Translator.deserializeLocalizationbyResource() - called 2016-01-31 22:50:29.717 ERROR [T] ISTA: [1] LicenseManager.verifyLicense() - failed with exception: BMW.Rheingold.CoreFramework.LicenseVerificationException: Error --- The session could not be successfully verified against the online portal. Check network connection and the validity of the portal session. at BMW.Rheingold.CoreFramework.LicenseManager.VerifyLicense() 2016-01-31 22:50:37.104 INFO [T] ISTA: [1] CoreFramework.CoreFramework() - license invalid or expired. 2016-01-31 22:50:37.104 INFO [T] ISTA: [1] CoreFramework.CoreFramework() - CoreFramework.DebugLevel is 0 2016-01-31 22:50:37.104 ERROR [T] ISTA: [1] LicenseManager.verifyLicense() - failed with exception: BMW.Rheingold.CoreFramework.LicenseVerificationException: Error --- The session could not be successfully verified against the online portal. Check network connection and the validity of the portal session. at BMW.Rheingold.CoreFramework.LicenseManager.VerifyLicense() 2016-01-31 22:50:37.106 INFO [T] ISTA: [1] PresentationFramework.PresentationFramework() - license invalid or expired. 2016-01-31 22:50:37.155 ERROR [T] ISTA: [1] ServiceLocator.GetService<T>() - No service registered for type "BMW.Rheingold.CoreFramework.Contracts.INavigationService". Using default instead. 2016-01-31 22:50:37.155 ERROR [T] ISTA: [1] ServiceLocator.GetService<T>() - No service registered for type "BMW.Rheingold.PresentationFramework.Print.IPrintingService". Using default instead. 2016-01-31 22:50:38.618 WARNING [T] ISTA: [1] TextContent.AsignFormattedText() - Failed to assign formatted text "Failed to start ISTA. Please make sure your ISTA configuration is valid. In doubt reset any non standard ISTA configuration and reinstall ISTA.". Assign paragraph with plain text "Failed to start ISTA. Please make sure your ISTA configuration is valid. In doubt reset any non standard ISTA configuration and reinstall ISTA." instead. Data at the root level is invalid. Line 1, position 1. 2016-01-31 22:50:38.621 WARNING [T] ISTA: [1] TextContent.AsignFormattedText() - Failed to assign formatted text "Failed to start ISTA. Please make sure your ISTA configuration is valid. In doubt reset any non standard ISTA configuration and reinstall ISTA.". Assign paragraph with plain text "Failed to start ISTA. Please make sure your ISTA configuration is valid. In doubt reset any non standard ISTA configuration and reinstall ISTA." instead. Data at the root level is invalid. Line 1, position 1. 2016-01-31 22:50:38.651 INFO [T] ISTA: [1] DatabaseProviderFactory.Instance() - Loading database provider of type: DatabaseProviderNone 2016-01-31 22:50:38.652 WARNING [T] ISTA: [1] DatabaseProvider.DatabaseProviderNone.Instance() - Using DatabaseProviderNone! 2016-01-31 22:50:38.676 INFO [T] ISTA: [1] ConfigSettings.set_CurrentCulture() - set UI culture to en-GB 2016-01-31 22:50:41.280 ERROR [T] ISTA: [1] ServiceLocator.GetService<T>() - No service registered for type "BMW.Rheingold.ISTAGUI.Navigation.INavigationServiceGui". Using default instead. Anyone who knows a solutution? Big thanks! RE: ISTA-D 4.15.23 Standalone / SQLiteDBs 4.15.21 - bigdiez - 02-26-2019 Hi... I have exactly same prob..... I installed on a PC Win10-64-bit previous versions of ISTA without problems.... Now I would installled ISTA on Laptop Lenovo i7 16GB RAM Win10-64 bit - but without success :-( Same problem as above !! Have you found a solution or have you solved your problem....!? I tested with newer ISTA-Version 4.15.31 --> same shit :-( Hope....anybody could help Thx's in advance...... RE: ISTA-D 4.15.23 Standalone / SQLiteDBs 4.15.21 - alexms590 - 06-10-2026 (12-19-2018, 10:53 AM)Spider80 Wrote: password please and thank you |
