Caterpillar Trim Files - Printable Version
+---- Forum: Caterpillar (https://mhhauto.com/Forum-Caterpillar)
+---- Thread: Caterpillar Trim Files (/Thread-Caterpillar-Trim-Files)
Caterpillar Trim Files - dr1c - 06-11-2011
Has anyone seen any Cat injector trim files floating around the net anywhere...Any will do but the 5232 0r 6999 and such would be sweet...
RE: Caterpillar Trim Files - hotrodherman - 06-11-2011
(06-11-2011, 06:48 AM)dr1c Wrote: Has anyone seen any Cat injector trim files floating around the net anywhere...Any will do but the 5232 0r 6999 and such would be sweet...
I believe what you are referring to are trim codes, like the c-15 CAT uses trim codes not files. The only cat engines that have trim files are the engines with a HEUI system. On the c-15 you can change the codes using cat ET.
There might be someone that knows a little more about this, so this is just from my experiences Listen
533
RE: Caterpillar Trim Files - dr1c - 06-11-2011
Yes that is what I'm referring to....I'm looking for (.trm) codes
RE: Caterpillar Trim Files - kylem - 06-12-2011
(06-11-2011, 07:54 PM)dr1c Wrote: Yes that is what I'm referring to....I'm looking for (.trm) codes
The trim codes are on the top of most injectors on the side of some . you just use et to program them in under the calibration section.
RE: Caterpillar Trim Files - RSwire - 06-12-2011
If you post the inj. serial number someone can get the trim file.
RE: Caterpillar Trim Files - acesneights - 08-18-2011
here are all the current acert trim files thru 2011 Fing32
Edit By Admin Patrian
Thanks for Sharing m8! Tup
BUT please read the MHH Rules at least for 1 time in your life! Kolo
http://mhhauto.com/Announcement-forum-rules--8
Rule #7
sorry,
I did read but apparently it Fing20 didn't sink in!
RE: Caterpillar Trim Files - giovimo80 - 08-20-2011
trimfile
RE: Caterpillar Trim Files - tklove04 - 05-16-2012
hi have c13 kcb67144 can someone help with trim files i have serial # for injectors they are
5e00514937ad
5e005149388d
5e00514957DE
5e00514942d0
e50000607037
e50004341851
thanks
