VCM II vs FLY FVDI J2534 vs VCM IDS 3 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Hardware. (https://mhhauto.com/Forum-Automotive-Hardware) +--- Thread: VCM II vs FLY FVDI J2534 vs VCM IDS 3 (/Thread-VCM-II-vs-FLY-FVDI-J2534-vs-VCM-IDS-3) |
VCM II vs FLY FVDI J2534 vs VCM IDS 3 - AfXv237 - 04-15-2019 Hello, I just found out that my tools are not enough and need to get one of the tools mentioned to initialize module on 2011+ Ford cars and vans. I did a lot of key programming, FIP/PCM initialization, on 2001 fords, 2006+, 2010, with Launch/Forscan, but on newer EURO5 cars I can only adapt keys, but can't initialize the ECU. It asks for incode by outcode, which I do not have access since code generators work until 05/2010 and my tools can't calculate it. So, what should I go for? VCM II clone, FLY FVDI J2534 or VCM IDS 3 RE: VCM II vs FLY FVDI J2534 vs VCM IDS 3 - diagnostix - 04-15-2019 VCM II HQ clone is best tool of that bunch, but be aware that you will still need incode/outcode for key/security related work. You do not normally need this for programmable module installation so long as there is already a PCM present which can be read by the VCM. RE: VCM II vs FLY FVDI J2534 vs VCM IDS 3 - AfXv237 - 04-15-2019 (04-15-2019, 02:12 PM)diagnostix Wrote: VCM II HQ clone is best tool of that bunch, but be aware that you will still need incode/outcode for key/security related work. You do not normally need this for programmable module installation so long as there is already a PCM present which can be read by the VCM. And where can I get it from? RE: VCM II vs FLY FVDI J2534 vs VCM IDS 3 - diagnostix - 04-15-2019 The member Floryn_P sells them. I understand there is a small wait from the factory for the HQ clones at the moment. Or for the very best, but more expensive option, search eBay USA for used genuine ones. These usually go for 5-600USD. RE: VCM II vs FLY FVDI J2534 vs VCM IDS 3 - AfXv237 - 04-15-2019 (04-15-2019, 05:20 PM)diagnostix Wrote: The member Floryn_P sells them. I understand there is a small wait from the factory for the HQ clones at the moment. Or for the very best, but more expensive option, search eBay USA for used genuine ones. These usually go for 5-600USD. No way i am paying that amount of money. I don't need it for 2019 mustangs. I need it for 2013 ford transit ecu initialization (SID208), as stated in first post. I am sure i don't need the genuine vcm. My question is which one does this job most reliable and if 135eur Clone could do the job? RE: VCM II vs FLY FVDI J2534 vs VCM IDS 3 - Sparky001 - 04-15-2019 Sp177-C or Sp177-C1. Are supposed to be the most reliable clones. I use... >> These guys Good luck RE: VCM II vs FLY FVDI J2534 vs VCM IDS 3 - AfXv237 - 04-16-2019 (04-15-2019, 11:37 PM)Sparky001 Wrote: Sp177-C or Sp177-C1. Are supposed to be the most reliable clones. I use... >> These guysThe link is not available. What version do you use and is it via VMware? RE: VCM II vs FLY FVDI J2534 vs VCM IDS 3 - Sparky001 - 04-16-2019 Oh, Sorry, Link only works if you register on their site. I still use FLY Clone Rotunda with V83. Works up till 2013/4 Will be getting SP177-C soonish.....Pretty sure it is a native install RE: VCM II vs FLY FVDI J2534 vs VCM IDS 3 - AfXv237 - 04-22-2019 (04-16-2019, 10:40 AM)Sparky001 Wrote: Oh, I have just ordered FLY FVDI J2534 for 117eur, 3-5 days shipping. It should do what I need it for. |
