Xentry Error 3.822 (3.XXX) - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Xentry Error 3.822 (3.XXX) (/Thread-Xentry-Error-3-822-3-XXX) |
Xentry Error 3.822 (3.XXX) - moscowretail - 10-25-2013 Hello Mhhauto users! I got a strange problem, can you help me guys? This is coming up always, when i start das second/third times without reboot xentry. When i try to diagnose "semi-old" cars (got vehicle block of the S220 98 years old), after closing xentry (via error) Das is work well. But, after attempt connect to new cars (E212), Das is didnt want to work correctly. Annotation Second part of error numbers is shows different everytime. Thanks in advance. RE: Xentry Error 3.822 (3.XXX) - alexopth1512 - 10-25-2013 version of Xentry? RE: Xentry Error 3.822 (3.XXX) - moscowretail - 10-25-2013 ohhh sry forget most impotant 01.13 xentry RE: Xentry Error 3.822 (3.XXX) - alexopth1512 - 10-25-2013 Usually you reinstall Xentry but before this you check. 1. your lic_key files are not readonly 2. your layoutmanager.dll are the original one. 3. You don't have commonlic.dll or layoutmanager.dll on other directories than the original (except zak/startutils) 4. you have correct kernel32.dll, advapi32.dll, user32.dll 5. you have installed all add-ons Good luck RE: Xentry Error 3.822 (3.XXX) - Pluto - 10-25-2013 Mr alexopth1512 appreciate your work, however could you edit your post and include the path to the files you referece----thanks RE: Xentry Error 3.822 (3.XXX) - alexopth1512 - 10-25-2013 lic_key_2.dat file are under c:\Documents and settings\all users\application data\licdir layoutmanager is under f:\programme\xentry\bin\plugins\com.daimler.layoutmanager_(version)\os\win32\x86 you should check if you find commonlic.dll under any subdirectory of c:\windows or f:\programme\xentry\bin and remove it. Only place commonlic.dll should be is c:\windows\zak\starutils RE: Xentry Error 3.822 (3.XXX) - Motasem - 11-03-2014 (10-25-2013, 08:13 PM)alexopth1512 Wrote: lic_key_2.dat file are under c:\Documents and settings\all users\application data\licdir Friend Good day Thank you for your post , BUT I do need from you some more information I did what you said step by step, and still have the same problem I do enter the DAS SIM on trucks from desktop and it gives me the same error AND if I did enter DAS SIM from the cars then go to trucks it opens normally and IF I use the Xentry Sim it gives me "internal error: (3.822)-3.197" I do face this on 07-2014 only and it is the first time Thank you RE: Xentry Error 3.822 (3.XXX) - Geniusman - 11-11-2014 Hi friends I faced this error with my teacher also..we r working to figure it out..wt we reach till now is re installing from zero and now we got one system stable.. the following is observed: 1. I notice win explorer stops working and instability after that error appears immediately 2. error results in VIN nonrecognition in real testing if u ignore. 3.After scan of the system and sources virus is detected in one of our systems 4.system installed successfully after cleaning but once an infected flash is plugged win explore instability issue and error appeared again.. form these observations this error is (most probably till now) because of win explorer instability caused by virus or something else still mysterious to us.. help and contribution is appreciated .. BEST REGARDS RE: Xentry Error 3.822 (3.XXX) - zdzich - 01-22-2015 (10-25-2013, 08:13 PM)alexopth1512 Wrote: lic_key_2.dat file are under c:\Documents and settings\all users\application data\licdir I did exactly what you suggested and my EWA stopped working. After trying to log in to EWA I get an Apache server error. It looks that deleting commonlic.dll file from EWA\lib folder caused the problem. So, now I'm restoring everything to the last working stage. |
