Iveco 3.0 EDC16C8 Tune - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Tuning. (https://mhhauto.com/Forum-Automotive-Tuning) +--- Thread: Iveco 3.0 EDC16C8 Tune (/Thread-Iveco-3-0-EDC16C8-Tune) |
Iveco 3.0 EDC16C8 Tune - jakesman - 06-28-2019 can some one do a tune for this iveco With EDC16c8 3.0 16 Valve , i need better fuell consumption but more power , it os NOT fitted with dpf or egr , straight forward read with galleto over OBD BOSCH EDC16/EDC16C8 0281 011 228 8-1.31 MPC55 30.07.2003 4Z.07-09-0608-09-06. 1037367762 1037366670 .Z.p_315 E3/ .Z.11.1.6 v4B,.. [attachment=314195] RE: Iveco 3.0 EDC16C8 Tune - Edc17tricore - 06-28-2019 (06-28-2019, 11:34 PM)jakesman Wrote: can some one do a tune for this iveco With EDC16c8 3.0 16 Valve , i need better fuell consumption but more power , it os NOT fitted with dpf or egr , straight forward If you need I can
RE: Iveco 3.0 EDC16C8 Tune - jakesman - 06-28-2019 at a price ? last guy that did tune for me was a disaster , i had to replace the flash chip , now im starting over RE: Iveco 3.0 EDC16C8 Tune - afrmotorsport - 06-29-2019 (06-28-2019, 11:43 PM)jakesman Wrote: at a price ? last guy that did tune for me was a disaster , i had to replace the flash chip , now im starting overYou replace the flash? Why? Is strange you had to replace Flash with a mod Inviato dal mio Mi 9 SE utilizzando Tapatalk RE: Iveco 3.0 EDC16C8 Tune - jakesman - 06-29-2019 loaded a "tuned file " ecu dead no coms nothing , maybe bad cs , took flash from anoter spare box and solder it into ecu , it was alive again , so the first tune file i got maybe had very bad cs and errors RE: Iveco 3.0 EDC16C8 Tune - 8ball - 06-29-2019 maybe it was your clone tool that bricked ECU? not 'bad' cs or the fact your tool couldnt do cs does the vehicle run ok with this sw? 1037370676. It does not match the ID you post i have stage 1 for the sw in file you have posted if you need, but dont want to waste time |
