(SOLVED)WIS/EPC SERVICE ACCESS AUTHORIZATION PROBLEM! - Printable Version
+---- Thread: (SOLVED)WIS/EPC SERVICE ACCESS AUTHORIZATION PROBLEM! (/Thread-SOLVED-WIS-EPC-SERVICE-ACCESS-AUTHORIZATION-PROBLEM)
(SOLVED)WIS/EPC SERVICE ACCESS AUTHORIZATION PROBLEM! - peter_pan - 08-21-2019
please help me to fix  Sever access authorization problem of WIS/EPC!
Thank!
RE: WIS/EPC SERVICE ACCESS AUTHORIZATION PROBLEM! - flterence - 08-22-2019
(08-21-2019, 09:22 PM)peter_pan Wrote: please help me to fix  Sever access authorization problem of WIS/EPC!
Thank!
Hi
Try update your I.E. to I.E. Version 11
Best Regards
RE: WIS/EPC SERVICE ACCESS AUTHORIZATION PROBLEM! - alexjx - 08-22-2019
i have this issue too.
the mac address always changes. i only use it for xentry(cd4 via lan) and i dont even turn on the wifi.
so changing keys is the only daily solution.
WIS/EPC SERVICE ACCESS AUTHORIZATION PROBLEM! - peter_pan - 08-22-2019
I updated IE 11. Wis work fine. And starfinder limited function
Sent from my iPhone using Tapatalk
(08-22-2019, 09:13 AM)peter_pan Wrote: I updated IE 11. Wis work fine. And starfinder limited function
Hi
Small tips
about the star finder limited problem is on Design Review 2013
Best Regards
RE: WIS/EPC SERVICE ACCESS AUTHORIZATION PROBLEM! - peter_pan - 08-26-2019
Try this solution.
https://mhhauto.com/Thread-XENTRY-DAS-ACTIVATION-KEY-REQUEST?pid=69065#pid69065
RE: (SOLVED)WIS/EPC SERVICE ACCESS AUTHORIZATION PROBLEM! - davex - 01-06-2023
Thank!
Hi! how did you solved?
RE: (SOLVED)WIS/EPC SERVICE ACCESS AUTHORIZATION PROBLEM! - BG.Blaze - 03-24-2026
? Any solution to this issue ? :
No valid server access authorization. Creation of workshops, groups and users not possible. Restricted changes only possible.
Fixed that issue by
1.unisltalling EWA and Java from control panel
2.delete :\Program Files (x86)\EWA and :\DB
3.installing everything by default on C: , previously i installed it on another drive.
This fixed my issue.
