vw touran 2009 steering angle sensor error - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: VAG Group VW , Audi, Seat, Skoda, Bentley Discussions. (https://mhhauto.com/Forum-VAG-Group-VW-Audi-Seat-Skoda-Bentley-Discussions) +---- Thread: vw touran 2009 steering angle sensor error (/Thread-vw-touran-2009-steering-angle-sensor-error) Pages:
vw touran 2009 steering angle sensor error - aigar - 10-16-2019 cant calibrate G85 Steering Angle sensor. Customer told us that someone changed steering rack. Fault in Central Electric: 01309 comes only when i drive with car. Can it be that installed steering rack is wrong or damaged? G85 is new and steering column control module is also changed. here is photos faults and basic settings. onedrive link. https://1drv.ms/f/s!AiW6b4K09xm1g_hO6QF2lwHfUtQAEw vw touran 2009 steering angle sensor error - Chris: - 10-16-2019 Hi! Everything is in the bag now in your case. I saw when new parts arrived and they was faulty. So, for first I think you should dig into the deep and come out with some testing results. - dtc's - wiring conditions - plugs, conector conditions etc... Then we can help you forder. Good luck my friend and I'm waiting for your progress. My best regards. Sent from my SM-J500F using Tapatalk RE: vw touran 2009 steering angle sensor error - Sparky001 - 10-16-2019 If SAS can't be adapted. I would suspect faulty installation of steering rack (Possibly one revolution out on shaft) Check how many turns from centre to full left lock & centre to full right lock. Also may just need an alignment Cheers RE: vw touran 2009 steering angle sensor error - aigar - 10-17-2019 yes Sparky001, can be. We just adjust week ago one Mercedes steering rack. Same case. I check it tommorow. This is when you work late. Cant think clear. RE: vw touran 2009 steering angle sensor error - guti_87 - 10-17-2019 If you change from second to third generation steering, you need to do a some adaptation with vcds 44 steering Adaptation Channel 3: 0 DSR Esp Front MK60 channel 9: 2 G85 MK60 Later you do a basic setting (g85) in ABS. RE: vw touran 2009 steering angle sensor error - aigar - 10-17-2019 i checked turns center to lock. Left 1,5 turns and right 1,5 turns. Seems to be ok. guti_87 about adaptation. Channel 9 should be 1 i think. Because 2 is only for MK70. picture https://1drv.ms/u/s!AiW6b4K09xm1g_hQ7-XqCBlT537jnw?e=B6CcHP RE: vw touran 2009 steering angle sensor error - guti_87 - 10-17-2019 Which reference do you have in Steering Wheel? Reference 1k0 959 549 CD, don't need a external G85 in the Steering wheel, only use a internal G85 from Steering assist. So should be changed to 0 in Channel 9. RE: vw touran 2009 steering angle sensor error - aigar - 10-17-2019 i have tried Channel 9 with 0 and with 1. No difference. here is video. https://1drv.ms/v/s!AiW6b4K09xm1g_howYgfgYF5SrVMYw?e=qiNzsw RE: vw touran 2009 steering angle sensor error - guti_87 - 10-17-2019 Try to change again to 0 in channel 9. The first Step is calibrate the internal g85 in 44 Steering and when it is ready. Finally calibrate G85 in abs. Good luck. |
