Online programming error with Xentry 2019-12 - Printable Version
+---- Thread: Online programming error with Xentry 2019-12 (/Thread-Online-programming-error-with-Xentry-2019-12)
Pages: 1 2 3 4 5 6
Online programming error with Xentry 2019-12 - apexi - 11-20-2019
Hello dear mhhauto.com colleagues
For few last days I am having problems with programming online via latest Xentry on all modules.
Error is attached.
SCN coding goes fine. It's just the programing of control units - it find's new software for it, but when you aggree to update the module it then throws this error.
All add-ons in the manager installed and up to date. Device C4 SDconnect clone.
Successfully programmed a car on DAS, but on xentry few cars and same result.
Can someone advise?
Thanks!
RE: Online programming error with Xentry 2019-12 - KG7222 - 11-20-2019
Did you install the front Sam with correct part number?
RE: Online programming error with Xentry 2019-12 - apexi - 11-20-2019
(11-20-2019, 07:08 PM)mbsupport Wrote: Did you install the front Sam with correct part number?
Yes. But the same error comes even when I go to update door module, it is not just SAM
RE: Online programming error with Xentry 2019-12 - jaysen - 11-20-2019
And you have also correctly configured the RDS (Retail Data Strorage) -> ConfigAssist?
Xentry Update Service is also working?
(11-20-2019, 07:22 PM)jaysen Wrote: And you have also correctly configured the RDS (Retail Data Strorage)  -> ConfigAssist?
I would say no. In configassist i don't see the Update Service. I remember it was available in ConfigAssist though when I installed 2019/09 previously.
The Xentry 2019/12 is installed and activated with this community's help.
Any directions how should I enable it?
Thanks!
RE: Online programming error with Xentry 2019-12 - Dublover - 11-20-2019
Yes, I have experienced the same error, on numerous machines. I also notice that in 12/2019 there is nowhere to configure the Xentry update service and retail data storage. It is missing from the config assist. If I use an earlier config assist to make my settings I get past this error, but then get another data storage error RDS_0003.
It does not even try to find the software on the laptop.
(11-20-2019, 07:35 PM)Dublover Wrote: Yes, I have experienced the same error, on numerous machines. I also notice that in 12/2019 there is nowhere to configure the Xentry update service and retail data storage. It is missing from the config assist. If I use an earlier config assist to make my settings I get past this error, but then get another data storage error RDS_0003.
Hm but if everyone would have this issue it would be quite massive. Hellooooo, does nobody else have same problems programming online with the latest version? Smile
Well I have seen it on 3 machines, all addons installed. Does anyone know where in 12/19 to configure the retail data storage? It does not appear in the config assist.
12/2019 is not available for general release yet, so few people have it.
RE: Online programming error with Xentry 2019-12 - dimonmers - 11-20-2019
Sorry
