BMW F11 6wb cluster swap - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Airbag, Dash, ECU, IMMO. (https://mhhauto.com/Forum-Automotive-Airbag-Dash-ECU-IMMO) +--- Thread: BMW F11 6wb cluster swap (/Thread-BMW-F11-6wb-cluster-swap) |
BMW F11 6wb cluster swap - BobbySD - 12-01-2019 Hey there, Im trying to retrofit 6WB cluster to a car. Someone before me was messing with it and im not sure what they did. Anyway I pull the 35160wt eep, read it and its empty which I think shouldnt be. Are there any programming option or I need dump? If so does anybody have a dump from: 6WB 0263695156 HW: 078 SW: D822 index: X70 Virginized will be cool and one more question is vin also somewhere else or just in this one eep? Thanks!! RE: BMW F11 6wb cluster swap - BobbySD - 12-01-2019 Ok I managed it by myself :X connection problems on programmer. Anyway, both vins match in the eep and tamper dot still available. Will be another vin instance in 95320? Thanks |
