Mitsubishi MUT-III PRE21061-00 + SEW23061-00 - Printable Version
+---- Forum: AUTO Software on Torrent (https://mhhauto.com/Forum-AUTO-Software-on-Torrent)
+---- Thread: Mitsubishi MUT-III PRE21061-00 + SEW23061-00 (/Thread-Mitsubishi-MUT-III-PRE21061-00-SEW23061-00)
Pages: 1 2 3 4 5 6
Mitsubishi MUT-III PRE21061-00 + SEW23061-00 - Aleksey-MS - 02-15-2020
Original Mitsubishi car diagnostic software. It works with MUT-3 and j2534 devices, like OpenPort 2.0, mini VCI.
[Image: mitsubishi-mut-3.jpg]
RE: Mitsubishi MUT-III 19091 - Torrent (without pass) - jerome110383 - 02-17-2020
Hello,
Please explain how to use with J2534 vci
RE: Mitsubishi MUT-III 19091 - Torrent (without pass) - Aleksey-MS - 02-18-2020
(02-17-2020, 03:17 PM)jerome110383 Wrote: Hello,
Hello. You need to install the passthru drivers.
RE: Mitsubishi MUT-III 19091 - Torrent (without pass) - trumnica - 02-22-2020
From ?
RE: Mitsubishi MUT-III 19091 - Torrent (without pass) - Aleksey-MS - 02-22-2020
(02-22-2020, 06:22 PM)trumnica Wrote: From ?
What do you mean?
RE: Mitsubishi MUT-III 19091 - Torrent (without pass) - mattydr67 - 02-22-2020
You need to use only MUT-III SE and in CAN BUS cars only.
You need to install your J2534 drivers.
Then you need  to use a patch/configurator/emulator which is still in developemnt and of course not for free.
Good luck
RE: Mitsubishi MUT-III 20011-00 - Torrent (without pass) - Aleksey-MS - 03-16-2020
There is a new version 2020 - PRE 20011-00
Mitsubishi MUT-III 20011-00 - Torrent (without pass) - anwarshine363 - 05-23-2020
How to change be connected by openport 2.0?
Sent from my SM-A305F using Tapatalk
RE: Mitsubishi MUT-III 20011-00 - Torrent (without pass) - Raulmax - 05-23-2020
Hello friend Aleksey-MS, a question, the Mitsubishi MUT-III 20011-00 can work with the original DPA5 interface, the Chinese NEXIQ I clone, or with the VAG-16 HEX + CAN Dual K & CAN-USB Chinese clone, with which of those 3 interface would work, thanks for your help Aleksey-MS
