BMW F32 - 420D xDrive- Encoding VTG Module - Printable Version
+--- Forum: Installation Guides, Procedures & Tutorials. (https://mhhauto.com/Forum-Installation-Guides-Procedures-Tutorials)
+--- Thread: BMW F32 - 420D xDrive- Encoding VTG Module (/Thread-BMW-F32-420D-xDrive-Encoding-VTG-Module)
BMW F32 - 420D xDrive- Encoding VTG Module - Integy - 03-19-2020
Hello Members!
I want ask about help with car from thread. I Need quick tutorial , how to code/write correct VIN to VTG module, after change for used one. I have ESYS OFC, and ISTA.
On car have dtc :
021908 Encoding: data invalid
02190B Encoding: Transmission failed
48097D Transfer box: Fault, clutch position known, no four wheel drive
RE: BMW F32 - 420D xDrive- Encoding VTG Module - elthox - 03-20-2020
(03-19-2020, 11:47 PM)Integy Wrote: Hello Members!
On car have dtc :
If flashing will be inevitable, you need to know also the donor car shipment istep.
RE: BMW F32 - 420D xDrive- Encoding VTG Module - mike1 - 01-08-2026
Ran into the same situation after replacing a used transfer case along with the module. A lot of rubbish information around the web.
Vtg in esys is marked as Lmv. Coded that with default values, adapted vtg with ista and calibrated - all done. No virgin or other bs.
