Help renew 272 ECU - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Help renew 272 ECU (/Thread-Help-renew-272-ECU) Pages:
Help renew 272 ECU - phuongnt - 12-30-2013 Hi, I tried to renew 272 ECU with MB ECU renew 1.7 but DAS is hung when it was in Teach in step. Please help me renew it correctly. Many thanks RE: Help renew 272 ECU - bawareca - 12-30-2013 Try with the modified E2prom and ext flash and reuse the int flash.If it doesnt work we will need a hint from a more experienced member. RE: Help renew 272 ECU - webmaster - 12-30-2013 Eeprom is enough.... Try this then report. Best regards. RE: Help renew 272 ECU - phuongnt - 12-30-2013 Interesting, EEPROM from bawareca and webmaster are identical. Thanks a lot for your both great support. I will test and report the result. BTW, do I need SCN coding for this renew or just do teach in / learning only? Regards. RE: Help renew 272 ECU - vanos batam - 12-30-2013 just do teach in / learning only!!!!!!!!!!!!!!! if problem.. i can help you RE: Help renew 272 ECU - phuongnt - 01-02-2014 Confirmed, only EEPROM needed, using drive authorization learning, no need SCN coding and engine can start now. Thanks all. RE: Help renew 272 ECU - gazchab - 01-03-2014 Can you please provide us with mb ecu clear 1.7 with a working keygen please thank you RE: Help renew 272 ECU - phuongnt - 01-04-2014 (01-03-2014, 09:34 PM)ghassan.chaabo Wrote: Can you please provide us with mb ecu clear 1.7 with a working keygen please thank you This is version I download from this forum. It says "no dongle found" but still generates the file. Try it. RE: Help renew 272 ECU - rambolee - 12-20-2016 eeprom data store at which chip? |
